Ana içeriğe geç
Whirlpool Refrigerator Freezer Thermistor Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: adım 2, 3 resimden 1. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: adım 2, 3 resimden 2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: adım 3, 2 resimden 1. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: adım 3, 2 resimden 2.
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: adım 4, 2 resimden 1. Whirlpool Refrigerator Freezer Thermistor Replacement: adım 4, 2 resimden 2.
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: adım 5, 3 resimden 1. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: adım 5, 3 resimden 2. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: adım 5, 3 resimden 3.
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: adım 6, 3 resimden 1. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: adım 6, 3 resimden 2. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: adım 6, 3 resimden 3.
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: adım 7, 3 resimden 1. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: adım 7, 3 resimden 2. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: adım 7, 3 resimden 3.
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: adım 8, 2 resimden 1. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: adım 8, 2 resimden 2.
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: adım 9, 1 resimden 1.
    • Remove the thermistor.
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: adım 10, 1 resimden 1.
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
nicO
15.945 İtibar
89 adet Kılavuz yazıldı
1Rehber Yorum
Does anyone know the thermistor part number it’s not listed on the parts breakdown
Tony - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 106
Her zaman: 3,824
