Ana içeriğe geç
Whirlpool Refrigerator Start Relay Assembly Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 1. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 2. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 3.
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: adım 4, 3 resimden 1. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: adım 4, 3 resimden 2. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: adım 4, 3 resimden 3.
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
  5. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: adım 5, 3 resimden 1. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: adım 5, 3 resimden 2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: adım 5, 3 resimden 3.
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
  6. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: adım 6, 3 resimden 1. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: adım 6, 3 resimden 2. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: adım 6, 3 resimden 3.
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the run capacitor, start relay, and overload relay.
  7. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: adım 7, 3 resimden 1. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: adım 7, 3 resimden 2. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: adım 7, 3 resimden 3.
    • If you own a multimeter, you can test the start relay and overload relay's resistance.
    • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
nicO
15.945 İtibar
89 adet Kılavuz yazıldı
2Kılavuz Yorumları
Is it universal part
dyannatorres@yahoo.com - Yanıt
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 109
Son 30 gün: 364
Her zaman: 14,167
