Ana içeriğe geç
Whirlpool Refrigerator Water Inlet Valve Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: adım 3, 3 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: adım 3, 3 resimden 2. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: adım 3, 3 resimden 3.
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: adım 4, 2 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: adım 4, 2 resimden 2.
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: adım 5, 3 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: adım 5, 3 resimden 2. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: adım 5, 3 resimden 3.
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: adım 6, 1 resimden 1.
    • Remove the screw(s) securing the inlet valve assembly.
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: adım 7, 3 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: adım 7, 3 resimden 2. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: adım 7, 3 resimden 3.
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: adım 8, 2 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement: adım 8, 2 resimden 2.
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: adım 9, 2 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: adım 9, 2 resimden 2.
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: adım 10, 3 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement: adım 10, 3 resimden 2. Whirlpool Refrigerator Water Inlet Valve Replacement: adım 10, 3 resimden 3.
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: adım 11, 3 resimden 1. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: adım 11, 3 resimden 2. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: adım 11, 3 resimden 3.
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: adım 12, 1 resimden 1.
    • Remove the inlet valve assembly from the chassis.
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: adım 13, 1 resimden 1.
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.945 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 71
Son 30 gün: 446
Her zaman: 11,609
