Ana içeriğe geç
Wii Balance Board Frame Replacement
Cory Olson
Cory Olson ve 3 diğer katkıda bulunanlar
En son June 27, 2021 tarihinde güncellendi
30 - 45 dakika
Orta
This guide will demonstrate how to replace the Power Supply inside the Wii Balance Board.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: adım 1, 1 resimden 1.
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Frame Replacement, Removing the Foot Cover: adım 2, 1 resimden 1.
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Frame Replacement, Removing the Foot: adım 3, 1 resimden 1.
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Frame Replacement, Removing the Additional Feet: adım 4, 1 resimden 1.
    • Repeat steps two and three on the remaining four feet.
    how to completely remove and then put back in would be helpful as that's what the title of this post is…. right?
    Nelda Murray - Yanıt
  5. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: adım 5, 1 resimden 1.
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Frame Replacement, Removing the Back Cover: adım 6, 1 resimden 1.
    • Lift off the gray back cover.
    Top Anleitung, aber kann nirgends die Platine finden.... Könnt ihr da helfen? Danke!!!
    Dominik - Yanıt
  7. Wii Balance Board Frame Replacement, Battery Compartment: adım 7, 2 resimden 1. Wii Balance Board Frame Replacement, Battery Compartment: adım 7, 2 resimden 2.
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Frame Replacement, Removing the Battery Case: adım 8, 1 resimden 1.
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
    Just wanted to say THANKS it really helped & saved me having to get a new one or repaired. u rock! Sending good karma your way!
    scottydecept - Yanıt
    Were can I get a battery case replacement holder for my wii fit balance board
    Jacqueline Booth - Yanıt
    Do we wipe down something after that?
    Kandace Lavender - Yanıt
    New batteries. Start “button" blinks, then turns off. Any suggestions?
    Ginny Butler - Yanıt
    After removing it I soaked the battery case in vinegar for maybe 30 minutes. A little toothbrush work and all of the crap was gone. Rinsed it, dried it, put it back in. While it soaked I also used vinegar on the spring battery terminal that is cabled to the base. Cleaned up very nicely.
    jatrac1 - Yanıt
  9. Wii Balance Board Frame Replacement, Unscrewing the Frame: adım 9, 1 resimden 1.
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Frame Replacement, Removing the Frame: adım 10, 1 resimden 1.
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
  11. Wii Balance Board Frame Replacement, Removing the Power Supply: adım 11, 1 resimden 1.
    • Lift out the power supply. It is not screwed in.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cory Olson
915 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014 üyesi
CPSU-FORTE-F14S13G8
5 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Dominik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 79
Her zaman: 3,565
