Ana içeriğe geç
Womier K66 Mechanical Keyboard Switch Replacement
Neye ihtiyacın var
  1. Womier K66 Mechanical Keyboard Switch Replacement, Switch: adım 1, 3 resimden 1. Womier K66 Mechanical Keyboard Switch Replacement, Switch: adım 1, 3 resimden 2. Womier K66 Mechanical Keyboard Switch Replacement, Switch: adım 1, 3 resimden 3.
    • Remove the keycaps from the keyboard using the keycap remover.
  2. Womier K66 Mechanical Keyboard Switch Replacement: adım 2, 3 resimden 1. Womier K66 Mechanical Keyboard Switch Replacement: adım 2, 3 resimden 2. Womier K66 Mechanical Keyboard Switch Replacement: adım 2, 3 resimden 3.
    • Flip the keyboard over so the backside is facing up.
    • Use the Phillips #0 screwdriver to remove the fourteen 1.52 mm screws.
    • Remove the back plate of the keyboard.
  3. Womier K66 Mechanical Keyboard Switch Replacement: adım 3, 3 resimden 1. Womier K66 Mechanical Keyboard Switch Replacement: adım 3, 3 resimden 2. Womier K66 Mechanical Keyboard Switch Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    • If you're unfamiliar with solder or need a refresher, review the How to Solder and Desolder guide.
    • Set your soldering iron to 400 °C.
    • Apply the soldering iron to the solder joints and remove the solder with the desoldering pump.
    • Be careful when soldering as the iron is very hot.
  4. Womier K66 Mechanical Keyboard Switch Replacement: adım 4, 3 resimden 1. Womier K66 Mechanical Keyboard Switch Replacement: adım 4, 3 resimden 2. Womier K66 Mechanical Keyboard Switch Replacement: adım 4, 3 resimden 3.
    • Remove the key switch from the board using the key switch puller.
  5. Womier K66 Mechanical Keyboard Switch Replacement: adım 5, 3 resimden 1. Womier K66 Mechanical Keyboard Switch Replacement: adım 5, 3 resimden 2. Womier K66 Mechanical Keyboard Switch Replacement: adım 5, 3 resimden 3.
    • Place your new switch onto the board.
    • In this case we used a Gateron Linear switch but this could be any variety of switches.
  6. Womier K66 Mechanical Keyboard Switch Replacement: adım 6, 3 resimden 1. Womier K66 Mechanical Keyboard Switch Replacement: adım 6, 3 resimden 2. Womier K66 Mechanical Keyboard Switch Replacement: adım 6, 3 resimden 3.
    • Apply new solder to the soldering joints of the replacement switch.
Sonuç
Minh-Tam Nguyen
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 800
