Ana içeriğe geç
Wyze Cam V2 Microphone Replacement
Oluajo
Oluajo ve 3 diğer katkıda bulunanlar
En son December 20, 2023 tarihinde güncellendi
45 dakika
Zor
İşlem Görüntüleri
Daha Fazla Görsel Gerekli
The Wyze Cam V2 comes with a electret condenser microphone that allows you to converse with people on the other side of the device. If your microphone becomes faulty it makes it hard to have conversations so you might need to get it replaced and this guide will walk you through the steps in doing that.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Wyze Cam V2 Microphone Replacement, Back Panel: adım 1, 1 resimden 1.
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
  2. Wyze Cam V2 Microphone Replacement: adım 2, 1 resimden 1.
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
  3. Wyze Cam V2 Microphone Replacement: adım 3, 2 resimden 1. Wyze Cam V2 Microphone Replacement: adım 3, 2 resimden 2.
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
  4. Wyze Cam V2 Microphone Replacement: adım 4, 2 resimden 1. Wyze Cam V2 Microphone Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
  5. Wyze Cam V2 Microphone Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
    • Carefully remove the motherboard from the device.
  6. Wyze Cam V2 Microphone Replacement: adım 6, 1 resimden 1.
    • Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
  7. Wyze Cam V2 Microphone Replacement: adım 7, 1 resimden 1.
    • Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
  8. Wyze Cam V2 Microphone Replacement, Microphone: adım 8, 1 resimden 1.
    • On the camera's motherboard locate the microphone labeled "MIC1".
  9. Wyze Cam V2 Microphone Replacement: adım 9, 1 resimden 1.
    • Desolder the iron piece holding down the microphone to the motherboard.
  10. Wyze Cam V2 Microphone Replacement: adım 10, 1 resimden 1.
    • Carefully detach the microphone from the motherboard.
Sonuç
Oluajo
243 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 26
Her zaman: 155
