Ana içeriğe geç
X-Street STR Viper Remote Control Motherboard Replacement
Neye ihtiyacın var
  1. X-Street STR Viper Remote Control Motherboard Replacement, Remote Control Motherboard: adım 1, 1 resimden 1.
    • Turn off the remote control. Flip power switch to the off position.
    • Remove the battery from bottom of the remote control for further safety measures.
  2. X-Street STR Viper Remote Control Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove all seven 3mm Phillips #2 screws from the underside panel.
  3. X-Street STR Viper Remote Control Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove five 3mm Phillips #2 screws that connect the motherboard to the back outer shell.
  4. X-Street STR Viper Remote Control Motherboard Replacement: adım 4, 1 resimden 1.
    • Detach the motherboard. Use soldering tools to desolder the red and black wires from the motherboard. To do this, refer to the how to solder/desolder page.
  5. X-Street STR Viper Remote Control Motherboard Replacement: adım 5, 1 resimden 1.
    • Replace the motherboard. Solder the wires back on to the new motherboard using the soldering kit. The black wire should be on the left and the red wire should be on the right.
Sonuç
Cate Kraska
129 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-6, Lancaster Spring 2015 Cal Poly, Team 12-6, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 663
