Ana içeriğe geç
X-Treme Tablet Generation 2 Battery Replacement
Neye ihtiyacın var
  1. X-Treme Tablet Generation 2 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Start on the edge of the top corner and use a spudger opening tool to carefully pry the back cover off of the main body.
    • Continue prying around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Battery Replacement: adım 2, 3 resimden 1. X-Treme Tablet Generation 2 Battery Replacement: adım 2, 3 resimden 2. X-Treme Tablet Generation 2 Battery Replacement: adım 2, 3 resimden 3.
    • Pull the cloth tape from the battery to free the body of the battery.
    • Use a solder vacuum and soldering iron to release the red, and then the black, wire from the motherboard.
  3. X-Treme Tablet Generation 2 Battery Replacement: adım 3, 2 resimden 1. X-Treme Tablet Generation 2 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the battery from the device.
    • Insert the new 3.7 V Li-Polymer battery into the device.
    • Use the soldering iron to solder the red, and then the black, wire back to motherboard.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mike Longshore
125 İtibar
1 Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-4, Prince Winter 2015 Pasco Hernando, Team 5-4, Prince Winter 2015 üyesi
PHSC-PRINCE-W15S5G4
6 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,092
