Ana içeriğe geç
Xbox 360 CPU Heat Sink Replacement
Neye ihtiyacın var
  1. Xbox 360 CPU Heat Sink Replacement, Hard Drive: adım 1, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
    FixBot'a Sor
    Yorum Ekle
  2. Xbox 360 CPU Heat Sink Replacement, Bottom Vent: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    FixBot'a Sor
    Yorum Ekle
  3. Xbox 360 CPU Heat Sink Replacement: adım 3, 3 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 3, 3 resimden 2. Xbox 360 CPU Heat Sink Replacement: adım 3, 3 resimden 3.
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
    FixBot'a Sor
    Yorum Ekle
  4. Xbox 360 CPU Heat Sink Replacement: adım 4, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 4, 2 resimden 2.
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
    FixBot'a Sor
    Yorum Ekle
  5. Xbox 360 CPU Heat Sink Replacement: adım 5, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 5, 2 resimden 2.
    • Repeat the same process to release the two center clips on the bottom vent.
    FixBot'a Sor
    Yorum Ekle
  6. Xbox 360 CPU Heat Sink Replacement: adım 6, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 6, 2 resimden 2.
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
    FixBot'a Sor
    Yorum Ekle
  7. Xbox 360 CPU Heat Sink Replacement: adım 7, 1 resimden 1.
    • Remove the bottom vent from the 360.
    FixBot'a Sor
    Yorum Ekle
  8. Xbox 360 CPU Heat Sink Replacement, Faceplate: adım 8, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement, Faceplate: adım 8, 2 resimden 2.
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
    FixBot'a Sor
    Yorum Ekle
  9. Xbox 360 CPU Heat Sink Replacement: adım 9, 1 resimden 1.
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
    FixBot'a Sor
    Yorum Ekle
  10. Xbox 360 CPU Heat Sink Replacement: adım 10, 1 resimden 1.
    • Remove the faceplate from the front face of the console.
    FixBot'a Sor
    Yorum Ekle
  11. Xbox 360 CPU Heat Sink Replacement, Top Vent: adım 11, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement, Top Vent: adım 11, 2 resimden 2.
    • Stand the console vertically with the top edge facing up.
    • The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
    FixBot'a Sor
    Yorum Ekle
  12. Xbox 360 CPU Heat Sink Replacement: adım 12, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 12, 2 resimden 2.
    • Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
    • You may also use the long finger of an Xbox 360 opening tool to accomplish this task.
    FixBot'a Sor
    Yorum Ekle
  13. Xbox 360 CPU Heat Sink Replacement: adım 13, 3 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 13, 3 resimden 2. Xbox 360 CPU Heat Sink Replacement: adım 13, 3 resimden 3.
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the top vent. Their locations are highlighted in red.
    FixBot'a Sor
    Yorum Ekle
  14. Xbox 360 CPU Heat Sink Replacement: adım 14, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 14, 2 resimden 2.
    • To release the clips, work from the middle of the top vent.
    • While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
    FixBot'a Sor
    Yorum Ekle
  15. Xbox 360 CPU Heat Sink Replacement: adım 15, 1 resimden 1.
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
    FixBot'a Sor
    Yorum Ekle
  16. Xbox 360 CPU Heat Sink Replacement: adım 16, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 16, 2 resimden 2.
    • The last clip is hidden underneath the rubber foot nearest the back of the console.
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
    • Remove the top vent from the 360.
    FixBot'a Sor
    Yorum Ekle
  17. Xbox 360 CPU Heat Sink Replacement, Lower Case: adım 17, 1 resimden 1.
    • Stand the console vertically with the top edge facing down.
    • Carefully peel the warranty sticker off the console.
    FixBot'a Sor
    Yorum Ekle
  18. Xbox 360 CPU Heat Sink Replacement: adım 18, 3 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 18, 3 resimden 2. Xbox 360 CPU Heat Sink Replacement: adım 18, 3 resimden 3.
    • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
    • Use the flat end of a spudger to release the following latches:
    • Above the front-facing USB ports.
    • Beneath the front-facing USB ports.
    • Above the Memory Unit slots.
    FixBot'a Sor
    Yorum Ekle
  19. Xbox 360 CPU Heat Sink Replacement: adım 19, 1 resimden 1.
    • Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
    FixBot'a Sor
    Yorum Ekle
  20. Xbox 360 CPU Heat Sink Replacement: adım 20, 1 resimden 1.
    • Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
    FixBot'a Sor
    Yorum Ekle
  21. Xbox 360 CPU Heat Sink Replacement: adım 21, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 21, 2 resimden 2.
    • The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
    FixBot'a Sor
    Yorum Ekle
  22. Xbox 360 CPU Heat Sink Replacement: adım 22, 3 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 22, 3 resimden 2. Xbox 360 CPU Heat Sink Replacement: adım 22, 3 resimden 3.
    • Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
    • While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
    FixBot'a Sor
    Yorum Ekle
  23. Xbox 360 CPU Heat Sink Replacement: adım 23, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 23, 2 resimden 2.
    • While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
    • The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
    FixBot'a Sor
    Yorum Ekle
  24. Xbox 360 CPU Heat Sink Replacement: adım 24, 1 resimden 1.
    • Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
    • Push the upper and lower cases apart to fully release the retaining clips.
    FixBot'a Sor
    Yorum Ekle
  25. Xbox 360 CPU Heat Sink Replacement: adım 25, 1 resimden 1.
    • Orient the console so that the front portion is facing downwards.
    • Grasp the back portion of the lower case and lift it upwards to separate it from the console.
    • Be careful not to excessively bend the lower case near the power plug, as it can crack easily.
    FixBot'a Sor
    Yorum Ekle
  26. Xbox 360 CPU Heat Sink Replacement, Eject Button: adım 26, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement, Eject Button: adım 26, 2 resimden 2.
    • Use the tip of a spudger to release the clip securing the eject button to the metal casing.
    • Insert the flat end of a spudger between the eject button and the optical drive.
    • Pry the eject button off its retaining posts and remove it from the 360.
    • This can also be accomplished using an Xbox 360 opening tool.
    FixBot'a Sor
    Yorum Ekle
  27. Xbox 360 CPU Heat Sink Replacement, Upper Case: adım 27, 1 resimden 1.
    • Remove the six silver 64 mm T10 Torx screws securing the upper case to the metal casing.
    FixBot'a Sor
    Yorum Ekle
  28. Xbox 360 CPU Heat Sink Replacement: adım 28, 1 resimden 1.
    • Orient the console so that the upper case is facing upwards.
    • Lift the upper case straight up and remove it from the console.
    FixBot'a Sor
    Yorum Ekle
  29. Xbox 360 CPU Heat Sink Replacement, Optical Drive: adım 29, 1 resimden 1.
    • Peel the silver tape securing the optical drive to the metal casing.
    FixBot'a Sor
    Yorum Ekle
  30. Xbox 360 CPU Heat Sink Replacement: adım 30, 1 resimden 1.
    • Slightly lift the optical drive upwards to gain clearance to disconnect the SATA and power connectors located on the backside of the optical drive.
    • Don't try to completely remove the optical drive just yet. Two cables still connect it to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  31. Xbox 360 CPU Heat Sink Replacement: adım 31, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 31, 2 resimden 2.
    • Grab the power connector by its cables and pull it straight out of its socket on the optical drive.
    • Disconnect the SATA data connector from its socket on the optical drive by pulling it straight away.
    FixBot'a Sor
    Yorum Ekle
  32. Xbox 360 CPU Heat Sink Replacement: adım 32, 1 resimden 1.
    • Lift the optical drive assembly out of the metal casing.
    FixBot'a Sor
    Yorum Ekle
  33. Xbox 360 CPU Heat Sink Replacement, Cooling Fan Duct: adım 33, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement, Cooling Fan Duct: adım 33, 2 resimden 2.
    • Insert the flat end of a spudger into the small rectangular opening on the top of the cooling fan duct.
    • Carefully release the fan duct retaining clip and remove the fan duct from the Xbox.
    • The clip can alternatively be released using the metal finger of an Xbox 360 opening tool.
    FixBot'a Sor
    Yorum Ekle
  34. Xbox 360 CPU Heat Sink Replacement, Dual Fans: adım 34, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement, Dual Fans: adım 34, 2 resimden 2.
    • While lifting the metal chassis strip above the dual fans, pull the fans toward the center of the motherboard.
    • Do not completely remove the dual fan assembly yet. Its cable is still attached to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  35. Xbox 360 CPU Heat Sink Replacement: adım 35, 1 resimden 1.
    • Lift the dual fan connector straight up from its socket on the motherboard.
    • Some fan connectors have a locking tab. If yours has a locking tab, be sure to depress it while disconnecting the fan from the motherboard.
    • Remove the dual fan assembly from the console.
    FixBot'a Sor
    Yorum Ekle
  36. Xbox 360 CPU Heat Sink Replacement, Motherboard: adım 36, 3 resimden 1. Xbox 360 CPU Heat Sink Replacement, Motherboard: adım 36, 3 resimden 2. Xbox 360 CPU Heat Sink Replacement, Motherboard: adım 36, 3 resimden 3.
    • Use the flat end of a spudger to release the clips securing the RF module shield along the top and the left edge of the RF module.
    • It may be easier to use your fingernail to release the clips from the RF module.
    • Remove the RF module shield from the console.
    FixBot'a Sor
    Yorum Ekle
  37. Xbox 360 CPU Heat Sink Replacement: adım 37, 1 resimden 1.
    • Remove three 5.6 mm T8 Torx screws securing the RF module to the metal chassis.
    FixBot'a Sor
    Yorum Ekle
  38. Xbox 360 CPU Heat Sink Replacement: adım 38, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 38, 2 resimden 2.
    • Grasp the RF module and lift it straight up to disconnect it from its socket on the motherboard.
    • Remove the RF module from the console.
    FixBot'a Sor
    Yorum Ekle
  39. Xbox 360 CPU Heat Sink Replacement: adım 39, 1 resimden 1.
    • Remove the following screws securing the motherboard to the metal casing:
    • Nine gold 11 mm T10 Torx screws.
    • Eight black 5.6 mm T8 Torx screws.
    • If you are reassembling your Xbox 360 after installing the Red Ring of Death Fix Kit, the eight T8 Torx screws circled in orange are not reused.
    FixBot'a Sor
    Yorum Ekle
  40. Xbox 360 CPU Heat Sink Replacement: adım 40, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 40, 2 resimden 2.
    • Turn the Xbox over, being careful not to let the motherboard fall out of the chassis.
    • Lift the motherboard assembly from its front edge.
    • Be careful not to damage the sockets as you rotate the motherboard away from the metal casing.
    • Remove the motherboard assembly from the metal casing.
    FixBot'a Sor
    Yorum Ekle
  41. Xbox 360 CPU Heat Sink Replacement, CPU Heat Sink: adım 41, 1 resimden 1.
    • Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink.
    • Pry the X clamp away from its retaining post until it is lifted above the small groove cut into the retaining post.
    FixBot'a Sor
    Yorum Ekle
  42. Xbox 360 CPU Heat Sink Replacement: adım 42, 2 resimden 1. Xbox 360 CPU Heat Sink Replacement: adım 42, 2 resimden 2.
    • Insert your screwdriver parallel to the motherboard between the X clamp and its retaining post.
    • Twist the screwdriver to fully release the X clamp from its retaining post.
    • Repeat this process for all four corners of the X clamp.
    • When removing the last corner of the x clamp and holding the logic board upside down, be sure to catch the CPU heat sink to avoid damage from it falling.
    FixBot'a Sor
    Yorum Ekle
  43. Xbox 360 CPU Heat Sink Replacement: adım 43, 1 resimden 1.
    • To reinstall the X clamp, first start by attaching two corners to the posts on the heat sink.
    • While holding the third arm of the X clamp down against the post attached to the heat sink, use a small flathead screwdriver to pry the X clamp away from the heat sink post.
    • As you pry, press down on the arm of the X clamp until you "walk" it down into the retaining groove cut into the post attached to the heat sink.
    • Repeat this process for the fourth arm of the X clamp.
    FixBot'a Sor
    Yorum Ekle
  44. Xbox 360 CPU Heat Sink Replacement: adım 44, 1 resimden 1.
    • Remove the CPU heat sink.
    • Before reinstalling the CPU heat sink, be sure to apply a new layer of thermal paste.
    • If you need to mount the heat sink back onto the motherboard, we have a thermal paste guide that makes replacing the thermal compound easy.
    FixBot'a Sor
    Yorum Ekle
Sonuç
55 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 95
Son 30 gün: 341
Her zaman: 64,632
