Giriş
This guide will show you how to replace the top panel on your Xbox 360 S.
Neye ihtiyacın var
In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
28 farklı kişi bu kılavuzu tamamladı.
