Ana içeriğe geç
Xbox Elite Wireless Controller Series 2 Top Housing Replacement
Neye ihtiyacın var
  1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: adım 1, 3 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: adım 1, 3 resimden 2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: adım 1, 3 resimden 3.
    • Use your fingers to remove the thumbstick toppers.
  2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the D-pad cover: adım 2, 2 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the D-pad cover: adım 2, 2 resimden 2.
    • Use your fingers to remove the D-pad cover.
  3. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Disassembly information: adım 3, 2 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Disassembly information: adım 3, 2 resimden 2.
    • The top housing is secured in two ways:
    • 13 tight plastic clips
    • Several strips of adhesive tape
  4. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: adım 4, 3 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: adım 4, 3 resimden 2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: adım 4, 3 resimden 3.
    • Releasing the plastic clips requires significant force. Take your time to avoid damaging your controller.
    • Insert an opening tool between the left bumper and the top housing.
    • Pry up the top housing to release the top left clip.
  5. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 5, 2 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 5, 2 resimden 2.
    • Insert an opening tool into the seam between the two housings on the controller’s left edge.
  6. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 6, 3 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 6, 3 resimden 2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 6, 3 resimden 3.
    • Slide the opening tool along the left edge and pry up intermittently to release the plastic clips.
  7. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 7, 3 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 7, 3 resimden 2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 7, 3 resimden 3.
    • Insert your opening tool into the seam between the two housings on the inner left edge.
    • Slide the opening tool along the bottom edge and pry up intermittently to release the plastic clips.
  8. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 8, 3 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 8, 3 resimden 2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 8, 3 resimden 3.
    • Insert your opening tool into the seam between the two housings on the controller’s right edge.
    • Slide the opening tool along the right edge and pry up intermittently to release the plastic clips.
  9. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 9, 2 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: adım 9, 2 resimden 2.
    • Insert your opening tool between the right bumper and the top housing.
    • Pry up the top housing to release the remaining plastic clips.
  10. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: adım 10, 3 resimden 1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: adım 10, 3 resimden 2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: adım 10, 3 resimden 3.
    • Remove the top housing.
    • To reinstall the top housing, position it on the midframe assembly and press down firmly along the edges to engage all of the clips.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Manuel Haeussermann
19.496 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.526 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 110
Son 30 gün: 480
Her zaman: 12,410
