Ana içeriğe geç
Xbox One Motherboard Replacement
Neye ihtiyacın var
  1. Xbox One Motherboard Replacement, Upper Case: adım 1, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  2. Xbox One Motherboard Replacement: adım 2, 2 resimden 1. Xbox One Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
    • The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
    FixBot'a Sor
    Yorum Ekle
  3. Xbox One Motherboard Replacement: adım 3, 2 resimden 1. Xbox One Motherboard Replacement: adım 3, 2 resimden 2.
    • There is a small plastic tab that reinforces the front corner of the Xbox.
    • Slide the tab straight back and remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Xbox One Motherboard Replacement: adım 4, 2 resimden 1. Xbox One Motherboard Replacement: adım 4, 2 resimden 2.
    • Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
    • There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
    • Leave the spudger in place until you open the case completely. The clips are very springy and may cause the case to snap shut while you're working.
    FixBot'a Sor
    Yorum Ekle
  5. Xbox One Motherboard Replacement: adım 5, 2 resimden 1. Xbox One Motherboard Replacement: adım 5, 2 resimden 2.
    • The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox.
    • Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
    FixBot'a Sor
    Yorum Ekle
  6. Xbox One Motherboard Replacement: adım 6, 2 resimden 1. Xbox One Motherboard Replacement: adım 6, 2 resimden 2.
    • Keep moving along the rear of the Xbox, prying up clips.
    • Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
    FixBot'a Sor
    Yorum Ekle
  7. Xbox One Motherboard Replacement: adım 7, 2 resimden 1. Xbox One Motherboard Replacement: adım 7, 2 resimden 2.
    • Keep popping clips. It may help to slide the plastic opening tool across the clips.
    • By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
    FixBot'a Sor
    Yorum Ekle
  8. Xbox One Motherboard Replacement: adım 8, 3 resimden 1. Xbox One Motherboard Replacement: adım 8, 3 resimden 2. Xbox One Motherboard Replacement: adım 8, 3 resimden 3.
    • Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
    • Use a plastic opening tool to pop any straggler clips that weren't freed.
    • Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
    • Lift the upper case slightly and shift it to give access to the front panel board.
    FixBot'a Sor
    Yorum Ekle
  9. Xbox One Motherboard Replacement: adım 9, 3 resimden 1. Xbox One Motherboard Replacement: adım 9, 3 resimden 2. Xbox One Motherboard Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it.
    • Use tweezers to lift the blue plastic retaining loop over the white connector on the board.
    • Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
    FixBot'a Sor
    Yorum Ekle
  10. Xbox One Motherboard Replacement: adım 10, 2 resimden 1. Xbox One Motherboard Replacement: adım 10, 2 resimden 2.
    • Use tweezers to pull the cable straight out of the connector on the board.
    • Remove the upper case.
    FixBot'a Sor
    Yorum Ekle
  11. Xbox One Motherboard Replacement, Reassembly Instructions: adım 11, 3 resimden 1. Xbox One Motherboard Replacement, Reassembly Instructions: adım 11, 3 resimden 2. Xbox One Motherboard Replacement, Reassembly Instructions: adım 11, 3 resimden 3.
    • The next 4 steps are directions for reassembly. Skip them to continue with disassembly.
    • Use the flat end of a spudger to free the clips securing the front panel to the upper case.
    • Remove the front panel from the rest of the upper case.
    FixBot'a Sor
    Yorum Ekle
  12. Xbox One Motherboard Replacement: adım 12, 3 resimden 1. Xbox One Motherboard Replacement: adım 12, 3 resimden 2. Xbox One Motherboard Replacement: adım 12, 3 resimden 3.
    • Replace the top part of the upper case.
    • Line up the clips and press firmly to re-seat them around the perimeter.
    FixBot'a Sor
    Yorum Ekle
  13. Xbox One Motherboard Replacement: adım 13, 3 resimden 1. Xbox One Motherboard Replacement: adım 13, 3 resimden 2. Xbox One Motherboard Replacement: adım 13, 3 resimden 3.
    • Support the front panel near the front of the Xbox.
    • Use tweezers to replace the front button cable in its ZIF socket.
    • Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
    FixBot'a Sor
    Yorum Ekle
  14. Xbox One Motherboard Replacement: adım 14, 3 resimden 1. Xbox One Motherboard Replacement: adım 14, 3 resimden 2. Xbox One Motherboard Replacement: adım 14, 3 resimden 3.
    • The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case.
    • With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
    • Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
    FixBot'a Sor
    Yorum Ekle
  15. Xbox One Motherboard Replacement, Upper Metal Case: adım 15, 3 resimden 1. Xbox One Motherboard Replacement, Upper Metal Case: adım 15, 3 resimden 2. Xbox One Motherboard Replacement, Upper Metal Case: adım 15, 3 resimden 3.
    • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
    • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
    • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
    FixBot'a Sor
    Yorum Ekle
  16. Xbox One Motherboard Replacement: adım 16, 3 resimden 1. Xbox One Motherboard Replacement: adım 16, 3 resimden 2. Xbox One Motherboard Replacement: adım 16, 3 resimden 3.
    • Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
    • Lift the Wi-Fi board straight up from its socket in the upper metal case.
    • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
    FixBot'a Sor
    Yorum Ekle
  17. Xbox One Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
    FixBot'a Sor
    Yorum Ekle
  18. Xbox One Motherboard Replacement: adım 18, 2 resimden 1. Xbox One Motherboard Replacement: adım 18, 2 resimden 2.
    • Lift—but do not remove—the upper metal case.
    • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  19. Xbox One Motherboard Replacement: adım 19, 2 resimden 1. Xbox One Motherboard Replacement: adım 19, 2 resimden 2.
    • Disconnect the Wi-Fi board interconnect cable from the motherboard.
    • Remove the upper metal case.
    FixBot'a Sor
    Yorum Ekle
  20. Xbox One Motherboard Replacement, Hard Drive Assembly: adım 20, 3 resimden 1. Xbox One Motherboard Replacement, Hard Drive Assembly: adım 20, 3 resimden 2. Xbox One Motherboard Replacement, Hard Drive Assembly: adım 20, 3 resimden 3.
    • Disconnect the hard drive SATA power and data cables from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  21. Xbox One Motherboard Replacement: adım 21, 1 resimden 1.
    • Lift and remove the hard drive tray from the Xbox.
    FixBot'a Sor
    Yorum Ekle
  22. Xbox One Motherboard Replacement, Optical Drive Assembly: adım 22, 3 resimden 1. Xbox One Motherboard Replacement, Optical Drive Assembly: adım 22, 3 resimden 2. Xbox One Motherboard Replacement, Optical Drive Assembly: adım 22, 3 resimden 3.
    • Disconnect the optical drive power and SATA data cables from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  23. Xbox One Motherboard Replacement: adım 23, 1 resimden 1.
    • Remove the optical drive assembly from the Xbox.
    FixBot'a Sor
    Yorum Ekle
  24. Xbox One Motherboard Replacement, Front Panel Board: adım 24, 1 resimden 1.
    • Lift the motherboard assembly out of the lower case.
    FixBot'a Sor
    Yorum Ekle
  25. Xbox One Motherboard Replacement: adım 25, 1 resimden 1.
    • Remove the three 9.5 mm T9 Torx screws securing the front panel board.
    FixBot'a Sor
    Yorum Ekle
  26. Xbox One Motherboard Replacement: adım 26, 1 resimden 1.
    • Disconnect the front panel board from its socket in the front of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  27. Xbox One Motherboard Replacement, Motherboard: adım 27, 3 resimden 1. Xbox One Motherboard Replacement, Motherboard: adım 27, 3 resimden 2. Xbox One Motherboard Replacement, Motherboard: adım 27, 3 resimden 3.
    • Two black plastic screw posts posts are attached to the frame with springy plastic barbs.
    • Pinch the arms together and pull the barbs out through the frame to remove the posts.
    FixBot'a Sor
    Yorum Ekle
  28. Xbox One Motherboard Replacement: adım 28, 2 resimden 1. Xbox One Motherboard Replacement: adım 28, 2 resimden 2.
    • Remove the 8.3 mm T9 Torx screw securing the white plastic screw post to the lower metal frame.
    • Remove the white plastic screw post from the frame.
    FixBot'a Sor
    Yorum Ekle
  29. Xbox One Motherboard Replacement: adım 29, 1 resimden 1.
    • Flip the lower metal frame and motherboard assembly over, to rest on the fan.
    • Remove the following screws from the bottom of the lower frame:
    • Four 11.2 mm T10 Torx screws
    • Four 9.5 mm T9 Torx screws
    FixBot'a Sor
    Yorum Ekle
  30. Xbox One Motherboard Replacement: adım 30, 3 resimden 1. Xbox One Motherboard Replacement: adım 30, 3 resimden 2. Xbox One Motherboard Replacement: adım 30, 3 resimden 3.
    • Two small plastic plugs protrude through the rear metal case—one beneath the side USB port, and another beneath the AC in port. These plugs get caught on the lower metal case and make it hard to remove the motherboard.
    • Push the two plugs through the lower metal case.
    FixBot'a Sor
    Yorum Ekle
  31. Xbox One Motherboard Replacement: adım 31, 1 resimden 1.
    • Lift the motherboard and heat sink/fan assembly out of the lower metal case.
    FixBot'a Sor
    Yorum Ekle
  32. Xbox One Motherboard Replacement: adım 32, 2 resimden 1. Xbox One Motherboard Replacement: adım 32, 2 resimden 2.
    • Disconnect the fan cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  33. Xbox One Motherboard Replacement: adım 33, 2 resimden 1. Xbox One Motherboard Replacement: adım 33, 2 resimden 2.
    • Insert the tip of a small flathead screwdriver between the post and the outer edge of one arm of the X-clamp.
    • Gently rotate the screwdriver, lifting the arm of the X-clamp up and off of the post.
    FixBot'a Sor
    Yorum Ekle
  34. Xbox One Motherboard Replacement: adım 34, 2 resimden 1. Xbox One Motherboard Replacement: adım 34, 2 resimden 2.
    • Use the same rotating technique to free one more arm of the X-clamp from its post.
    • Remove the X-clamp.
    FixBot'a Sor
    Yorum Ekle
  35. Xbox One Motherboard Replacement: adım 35, 2 resimden 1. Xbox One Motherboard Replacement: adım 35, 2 resimden 2.
    • Lift the motherboard off of the fan/heat sink assembly.
    • When you're reassembling your Xbox, follow our Applying Thermal Paste guide at this point to apply a new layer of thermal paste to the CPU.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Don't forget to apply a new layer of thermal paste to your CPU. Follow this guide to learn how.
63 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
515.338 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.359 adet Kılavuz yazıldı
7Kılavuz Yorumları
Quick question. After reassembly do you need to reinstall an operating system or update anything thing or does the hard drive just go oh look new stuff yeah that's fine.
Matt Glenn - Yanıt Paylaş
It depends - the hard drive needs to have it’s operating system files up to date to match whatever is flashed onto the motherboard. If the two dont match you get error E106. You can solve this https://support.xbox.com/en-US/xbox-one/...
James Heinrich - Yanıt Paylaş
My Xbox 1 will turn on and within 2 mins or less back off on it's on. I know for a fact it's not the power source, brick or cords. They work on another console. Any info would be awesome. Thanks!
Brian - Yanıt Paylaş
Brian, same issue here. I replaced capacitors on my brick last year and works on another console. I have tried numerous reset options as well. I opened up and cleaned dust out with air compressor and 99% isopropyl alcohol. I also replaced the thermal paste on the processor and removed old paste carefully with alcohol. It still does the same thing like yours above. Turns on, fan turns on, no display, then turns off within 1-2 minutes. None of what I did above changed it, so decided between replacing motherboard or hard drive. I have my Xbox connected to external USB SSD, but still no avail. Not sure if my external had the OS on it though.
schleterbrandon - Yanıt Paylaş
Have any of you had issues even after replacing the motherboard? Like, did it go out on you a couple months later? Did it still run the same? Time sensitive question please answer, thanks! Can't keep checking, o if you have an answer please contact me on Instagram at ugli_boi99
Mason Wolfe - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 94
Son 30 gün: 521
Her zaman: 98,649
