Ana içeriğe geç
Xbox One S All Digital Edition Fan Replacement
Neye ihtiyacın var
  1. Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: adım 1, 3 resimden 1. Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: adım 1, 3 resimden 2. Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: adım 1, 3 resimden 3.
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Fan Replacement: adım 2, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement: adım 2, 2 resimden 2.
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Fan Replacement: adım 3, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement: adım 3, 2 resimden 2.
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Fan Replacement: adım 4, 1 resimden 1.
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Fan Replacement, Top Metal Shield: adım 5, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement, Top Metal Shield: adım 5, 2 resimden 2.
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Fan Replacement: adım 6, 3 resimden 1. Xbox One S All Digital Edition Fan Replacement: adım 6, 3 resimden 2. Xbox One S All Digital Edition Fan Replacement: adım 6, 3 resimden 3.
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Fan Replacement, IR Blaster: adım 7, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement, IR Blaster: adım 7, 2 resimden 2.
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  8. Xbox One S All Digital Edition Fan Replacement: adım 8, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement: adım 8, 2 resimden 2.
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  9. Xbox One S All Digital Edition Fan Replacement, Wifi Card: adım 9, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement, Wifi Card: adım 9, 2 resimden 2.
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  10. Xbox One S All Digital Edition Fan Replacement: adım 10, 1 resimden 1.
    • Carefully remove the WiFi Card from the metal chassis.
  11. Xbox One S All Digital Edition Fan Replacement, Bottom Metal Shield: adım 11, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement, Bottom Metal Shield: adım 11, 2 resimden 2.
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Fan Replacement: adım 12, 3 resimden 1. Xbox One S All Digital Edition Fan Replacement: adım 12, 3 resimden 2. Xbox One S All Digital Edition Fan Replacement: adım 12, 3 resimden 3.
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Fan Replacement: adım 13, 3 resimden 1. Xbox One S All Digital Edition Fan Replacement: adım 13, 3 resimden 2. Xbox One S All Digital Edition Fan Replacement: adım 13, 3 resimden 3.
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Fan Replacement, Fan: adım 14, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement, Fan: adım 14, 2 resimden 2.
    • Locate the 4-pin connector on the side of the fan assembly.
    • Disconnect the cable from the motherboard.
  15. Xbox One S All Digital Edition Fan Replacement: adım 15, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement: adım 15, 2 resimden 2.
    • Use a spudger to pry the fan tabs up and away from the heatsink.
    • Getting the fan detached can take some force. A metal tool might be required.
  16. Xbox One S All Digital Edition Fan Replacement: adım 16, 2 resimden 1. Xbox One S All Digital Edition Fan Replacement: adım 16, 2 resimden 2.
    • Lift the fan away to fully remove it.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jules Hajjar
1.915 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G6
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 36
Son 30 gün: 164
Her zaman: 10,852
