Ana içeriğe geç
Xbox One S All Digital Edition Power Supply Replacement
Neye ihtiyacın var
  1. Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: adım 1, 3 resimden 1. Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: adım 1, 3 resimden 2. Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: adım 1, 3 resimden 3.
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Power Supply Replacement: adım 2, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement: adım 2, 2 resimden 2.
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Power Supply Replacement: adım 3, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement: adım 3, 2 resimden 2.
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Power Supply Replacement: adım 4, 1 resimden 1.
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: adım 5, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: adım 5, 2 resimden 2.
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Power Supply Replacement: adım 6, 3 resimden 1. Xbox One S All Digital Edition Power Supply Replacement: adım 6, 3 resimden 2. Xbox One S All Digital Edition Power Supply Replacement: adım 6, 3 resimden 3.
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: adım 7, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: adım 7, 2 resimden 2.
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  8. Xbox One S All Digital Edition Power Supply Replacement: adım 8, 1 resimden 1.
    • Carefully remove the WiFi Card from the metal chassis.
  9. Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: adım 9, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: adım 9, 2 resimden 2.
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  10. Xbox One S All Digital Edition Power Supply Replacement: adım 10, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement: adım 10, 2 resimden 2.
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  11. Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: adım 11, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: adım 11, 2 resimden 2.
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Power Supply Replacement: adım 12, 3 resimden 1. Xbox One S All Digital Edition Power Supply Replacement: adım 12, 3 resimden 2. Xbox One S All Digital Edition Power Supply Replacement: adım 12, 3 resimden 3.
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Power Supply Replacement: adım 13, 3 resimden 1. Xbox One S All Digital Edition Power Supply Replacement: adım 13, 3 resimden 2. Xbox One S All Digital Edition Power Supply Replacement: adım 13, 3 resimden 3.
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Power Supply Replacement, Power Supply: adım 14, 3 resimden 1. Xbox One S All Digital Edition Power Supply Replacement, Power Supply: adım 14, 3 resimden 2. Xbox One S All Digital Edition Power Supply Replacement, Power Supply: adım 14, 3 resimden 3.
    • Gently lift the hard drive to free up some space around the power supply.
  15. Xbox One S All Digital Edition Power Supply Replacement: adım 15, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement: adım 15, 2 resimden 2.
    • Lift the power supply up and away from the motherboard.
  16. Xbox One S All Digital Edition Power Supply Replacement: adım 16, 2 resimden 1. Xbox One S All Digital Edition Power Supply Replacement: adım 16, 2 resimden 2.
    • Disconnect the six pin connector from the motherboard.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jules Hajjar
1.915 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G6
4 Üyeler
32 adet Kılavuz yazıldı
4Kılavuz Yorumları
I replaced the power supply and my Xbox still isn't turning on. I used a power supply I got from this website. Please help
William Oliver - Yanıt
Another issue could be the power button on the front power board. If possible, you could try to replace that as well.
Jules Hajjar -
replace the PSU and still boots up and shuts off
imafuxer - Yanıt
Completed this process and replaced with a new power supply bought here... Eureka! Fired right back up after re-assembly! Thank you iFixIt... I bought the tool kit and power supply here and everything worked great! I even ended up needing one of the super tiny Torx heads for a clock spring replacement job on my truck, and it was nice to just have it on hand!
Arash E - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 51
Son 30 gün: 213
Her zaman: 9,906
