Ana içeriğe geç
Xbox One S All Digital Edition Top Metal Shield Replacement
Neye ihtiyacın var
  1. Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: adım 1, 3 resimden 1. Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: adım 1, 3 resimden 2. Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: adım 1, 3 resimden 3.
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Top Metal Shield Replacement: adım 2, 2 resimden 1. Xbox One S All Digital Edition Top Metal Shield Replacement: adım 2, 2 resimden 2.
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Top Metal Shield Replacement: adım 3, 2 resimden 1. Xbox One S All Digital Edition Top Metal Shield Replacement: adım 3, 2 resimden 2.
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Top Metal Shield Replacement: adım 4, 1 resimden 1.
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Top Metal Shield Replacement, Top Metal Shield: adım 5, 2 resimden 1. Xbox One S All Digital Edition Top Metal Shield Replacement, Top Metal Shield: adım 5, 2 resimden 2.
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Top Metal Shield Replacement: adım 6, 3 resimden 1. Xbox One S All Digital Edition Top Metal Shield Replacement: adım 6, 3 resimden 2. Xbox One S All Digital Edition Top Metal Shield Replacement: adım 6, 3 resimden 3.
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jules Hajjar
1.807 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G6
4 Üyeler
31 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 12
Son 30 gün: 23
Her zaman: 954
