Ana içeriğe geç
Xbox One Stereo Headset Microphone Replacement
Neye ihtiyacın var
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: adım 1, 3 resimden 1. Xbox One Stereo Headset Microphone Replacement, Microphone: adım 1, 3 resimden 2. Xbox One Stereo Headset Microphone Replacement, Microphone: adım 1, 3 resimden 3.
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
    FixBot'a Sor
    Yorum Ekle
  2. Xbox One Stereo Headset Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
    FixBot'a Sor
    Yorum Ekle
  3. Xbox One Stereo Headset Microphone Replacement: adım 3, 1 resimden 1.
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
    FixBot'a Sor
    Yorum Ekle
  4. Xbox One Stereo Headset Microphone Replacement: adım 4, 3 resimden 1. Xbox One Stereo Headset Microphone Replacement: adım 4, 3 resimden 2. Xbox One Stereo Headset Microphone Replacement: adım 4, 3 resimden 3.
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
    FixBot'a Sor
    Yorum Ekle
  5. Xbox One Stereo Headset Microphone Replacement: adım 5, 1 resimden 1.
    • Pull the back plate off the boom.
    FixBot'a Sor
    Yorum Ekle
  6. Xbox One Stereo Headset Microphone Replacement: adım 6, 1 resimden 1.
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Trevor Steele
233 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-37, Amido Winter 2015 Cal Poly, Team 17-37, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G37
4 Üyeler
5 adet Kılavuz yazıldı
9Kılavuz Yorumları
Is a replacement microphone available from iFixit?
Scott Minton - Yanıt Paylaş
What do you replace the mic with?
Its Me - Yanıt Paylaş
They have the microphone for sale
daniel david guerrerogarcia - Yanıt Paylaş
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Yanıt Paylaş
Any mod to make the cable removable?
kikis.andcream - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 69
Her zaman: 24,913
