Ana içeriğe geç
Xbox One Stereo Headset Microphone Replacement
Neye ihtiyacın var
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: adım 1, 3 resimden 1. Xbox One Stereo Headset Microphone Replacement, Microphone: adım 1, 3 resimden 2. Xbox One Stereo Headset Microphone Replacement, Microphone: adım 1, 3 resimden 3.
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: adım 3, 1 resimden 1.
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: adım 4, 3 resimden 1. Xbox One Stereo Headset Microphone Replacement: adım 4, 3 resimden 2. Xbox One Stereo Headset Microphone Replacement: adım 4, 3 resimden 3.
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: adım 5, 1 resimden 1.
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: adım 6, 1 resimden 1.
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Trevor Steele
233 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-37, Amido Winter 2015 Cal Poly, Team 17-37, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G37
4 Üyeler
5 adet Kılavuz yazıldı
9Kılavuz Yorumları
Is a replacement microphone available from iFixit?
Scott Minton - Yanıt
What do you replace the mic with?
Its Me - Yanıt
They have the microphone for sale
daniel david guerrerogarcia - Yanıt
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Yanıt
Any mod to make the cable removable?
kikis.andcream - Yanıt
Hey guys, the back plate of my mic has fallen off by itself how can I fix it
XteriorFury - Yanıt
Where can we get the microphone piece from? Is it universal or a specific type?
Oliver - Yanıt
Anyone know where I can order a replacement mic for my Microsoft Armed forces stereo headset?
thanks
Skyler Bell - Yanıt
Why doesn’t this guide specify where to purchase the replacement mic? Same goes for the speaker replacement guide, great instructions how to replace but not what to replace them with or where to buy?
BattleBorn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 50
Her zaman: 24,164
