Ana içeriğe geç
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
Neye ihtiyacın var
  1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: adım 1, 2 resimden 1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: adım 1, 2 resimden 2.
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 2, 2 resimden 1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Only use a pry tool! The vibration motor wires are exposed and directly accessible from the side when opening. I attempted to open it with a small knife, expecting to be able to gently pry the clips open, accidentally sliced through my right motor’s wires.
    Sawyer Coe - Yanıt
    If you have some Guitar picks laying around they work GREAT!
    Mike Beane - Yanıt
    For some reason, the two closest hinges at the top of the two handle covers are extremely strong. I had to play around to get them off unlike several guides and video tutorials that, I don't know how, take them off without the slightest effort.
    Controller wireless Xbox One Model 1708
    Stefano Spinelli - Yanıt
  3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 3, 1 resimden 1.
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Torx-8 security bits work as well.
    jahiamir - Yanıt
    Torx 8 or 9 wasn’t working. I used 2.0 minus screwdriver
    richjlee - Yanıt
    The 2.0 minus worked for me as well.
    metric - Yanıt
    When sliding in the plastic cover during reassembly be sure it lines up with the battery compartment contacts. It can be really easy to not see it and bend the contacts. If you still encounter force during this step, depressing the triggers out of the way worked for me.
    Drew - Yanıt
    Since mine is out of warranty I just broke out the security nib with a 2.0 standard bit. Then used a T8 torx.
    Tim LaCrosse - Yanıt
  4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 4, 2 resimden 1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 4, 2 resimden 2.
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 5, 1 resimden 1.
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    Reassembly: When placing the back cover on: notice that the battery terminals need to slide inside the cover first. Then compress the triggers slightly, Then the cover will be aligned correctly. Then add the front cover and add screws so it doesn’t come undone.
    hunteil - Yanıt
    It isn't necessary to take off the back cover
    Otto Hahn - Yanıt
  6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: adım 6, 3 resimden 1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: adım 6, 3 resimden 2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: adım 6, 3 resimden 3.
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
    if you replace thumbsticks only, this step is NOT required and it is safer not to remove bottom cover, removing faceplate is sufficient to replace thumbsticks
    Piotr Wysocki - Yanıt
Sonuç
56 farklı kişi bu kılavuzu tamamladı.
Weston Gilmore
1.990 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 üyesi
CPSU-FORTE-F17S18G3
4 Üyeler
34 adet Kılavuz yazıldı
4 Yorum
i used a t8 and it worked
Rudy Bp - Yanıt
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - Yanıt
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - Yanıt
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 119
Son 30 gün: 614
Her zaman: 29,359
