Ana içeriğe geç
Xbox One Wireless Controller Model 1708 Top Motherboard Replacement
Neye ihtiyacın var
  1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: adım 1, 2 resimden 1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: adım 1, 2 resimden 2.
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: adım 2, 2 resimden 1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: adım 3, 1 resimden 1.
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: adım 4, 3 resimden 1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: adım 4, 3 resimden 2. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: adım 4, 3 resimden 3.
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: adım 5, 2 resimden 1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: adım 5, 2 resimden 2.
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: adım 6, 1 resimden 1.
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
  7. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Directional Pad: adım 7, 1 resimden 1.
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
  8. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Joystick Caps: adım 8, 1 resimden 1.
    • Pull the joysticks off of the controller.
  9. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Top Motherboard: adım 9, 1 resimden 1.
    • If the rumble motors fall out of frame, the wires may disconnect from the motherboard . The wires will have to be soldered to reattach the motor.
    • Turn the device over and remove the two 7mm torx-6 screws in the bottom left and right corners.
  10. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: adım 10, 3 resimden 1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: adım 10, 3 resimden 2. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: adım 10, 3 resimden 3.
    • Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
    • The top motherboard is still connected to the bottom motherboard. To fully separate the top motherboard, you will need to use a soldering iron.
    • Warning: Do not attempt to disconnect the shielded (gold colored) connector as it is extremely fragile you will break it. It runs between the two boards.
    • De-solder the shielded cable from the lower board instead of attempting to disconnect the connector. De-solder using micro soldering techniquest.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Lien (Ally) Quan
918 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 üyesi
CPSU-FORTE-F17S18G3
4 Üyeler
32 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 101
Son 30 gün: 404
Her zaman: 25,841
