Ana içeriğe geç
Xbox One Wireless Controller Top Motherboard Replacement
Neye ihtiyacın var
    1. Xbox One Wireless Controller Top Motherboard Replacement, Battery Pack: adım 1, 1 resimden 1.
      • Remove the battery pack cover.
      • Remove batteries.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox One Wireless Controller Top Motherboard Replacement, Side Handles: adım 2, 2 resimden 1. Xbox One Wireless Controller Top Motherboard Replacement, Side Handles: adım 2, 2 resimden 2.
      • We recommend using a nylon spudger for this step. A metal spudger is shown.
      • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
      • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
      FixBot'a Sor
      Yorum Ekle
    3. Xbox One Wireless Controller Top Motherboard Replacement, Screws: adım 3, 2 resimden 1. Xbox One Wireless Controller Top Motherboard Replacement, Screws: adım 3, 2 resimden 2.
      • There is a hidden screw located in the middle of the controller behind the label.
      • Use a screwdriver and punch a hole directly in the center of the label.
      • You may also lift the label if you do not want to puncture it.
      • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Xbox One Wireless Controller Top Motherboard Replacement, Backplate: adım 4, 1 resimden 1.
      • Remove the backplate.
      FixBot'a Sor
      Yorum Ekle
    5. Xbox One Wireless Controller Top Motherboard Replacement, Faceplate: adım 5, 1 resimden 1.
      • Remove the faceplate.
      FixBot'a Sor
      Yorum Ekle
    1. Xbox One Wireless Controller Top Motherboard Replacement, Top Motherboard: adım 6, 2 resimden 1. Xbox One Wireless Controller Top Motherboard Replacement, Top Motherboard: adım 6, 2 resimden 2.
      • You may let the rumble motors hang freely out of their sockets.
      • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
      • De-solder the black and gray wires that are attached to the top motherboard.
      • Remove the rumble motors and set them aside.
      • Be careful while using the soldering iron not to damage other components or hurt yourself.
      • For information on how to solder, click here.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox One Wireless Controller Top Motherboard Replacement: adım 7, 1 resimden 1.
      • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
      FixBot'a Sor
      Yorum Ekle
    3. Xbox One Wireless Controller Top Motherboard Replacement: adım 8, 1 resimden 1.
      • Firmly grip sides of motherboard near the middle.
      • Lift upwards while slightly wiggling the motherboard forward and backward.
      • Lifting the motherboard will require some force.
      FixBot'a Sor
      Yorum Ekle
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Liam Gow
5.594 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-15, Maness Winter 2015 Cal Poly, Team 20-15, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G15
5 Üyeler
62 adet Kılavuz yazıldı
6Kılavuz Yorumları
where can i get a top motherborde replacement??
Lol John - Yanıt Paylaş
Hi John,
Unfortunately, beyond the parts list given on the main page, I don't know of any other reliable links. I'd suggest Googling the part, or maybe searching on eBay.
Liam Gow - Yanıt Paylaş
I was only able to unscrew 2 of the Torx screws. They have a pin right in the middle that doesn't allow for the screwdriver to be fully inserted, or at all. The two screws I was able to unscrew must've had a shorter pin than the others.
Rami Girgis - Yanıt Paylaş
These points on the head is what we call a security torx screw. You will need the specific T8 or T6 Security Torx Screwdriver to remove these screws.
jbagge0023 - Yanıt Paylaş
You can use a small flat blade screwdriver ;-)
If any of the screws are tight, the centre pin may snap, then you can just use a normal Torx bit.
Lee Houston - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 67
Son 30 gün: 247
Her zaman: 82,682
