Ana içeriğe geç
Xbox Series S Plastic Case Replacement
Neye ihtiyacın var
  1. Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: adım 1, 3 resimden 1. Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: adım 1, 3 resimden 2. Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
  2. Xbox Series S Plastic Case Replacement, Remove the back panel screws: adım 2, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    Satın Al
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Plastic Case Replacement, Remove the bottom panel: adım 3, 3 resimden 1. Xbox Series S Plastic Case Replacement, Remove the bottom panel: adım 3, 3 resimden 2. Xbox Series S Plastic Case Replacement, Remove the bottom panel: adım 3, 3 resimden 3.
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Plastic Case Replacement, Remove the plastic case screws: adım 4, 1 resimden 1.
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Plastic Case Replacement, Remove the plastic case: adım 5, 3 resimden 1. Xbox Series S Plastic Case Replacement, Remove the plastic case: adım 5, 3 resimden 2. Xbox Series S Plastic Case Replacement, Remove the plastic case: adım 5, 3 resimden 3.
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Plastic Case Replacement: adım 6, 3 resimden 1. Xbox Series S Plastic Case Replacement: adım 6, 3 resimden 2. Xbox Series S Plastic Case Replacement: adım 6, 3 resimden 3.
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
Robert Boyd
26.668 İtibar
94 adet Kılavuz yazıldı
3 Yorum
Where can i find custom case for the xbox series s?
Joe - Yanıt
What about the back plate?
Legitti - Yanıt
it says you cant remove it
Pavement Creator - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 38
Son 7 gün: 221
Son 30 gün: 1,029
Her zaman: 27,294
