Ana içeriğe geç
Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement
Neye ihtiyacın var
  1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: adım 1, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: adım 1, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: adım 1, 3 resimden 3.
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: adım 2, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: adım 2, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: adım 2, 3 resimden 3.
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 3, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 3, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 3, 3 resimden 3.
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
    Before doing this step, it is recommended to clean the edges of the cover
    Violynos - Yanıt
    Thanks for adding this tip!
    Manuel Haeussermann -
  4. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: adım 4, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: adım 4, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: adım 4, 3 resimden 3.
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: adım 5, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: adım 5, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: adım 5, 3 resimden 3.
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 6, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 6, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 6, 3 resimden 3.
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: adım 7, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: adım 7, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: adım 7, 3 resimden 3.
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: adım 8, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: adım 8, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: adım 8, 3 resimden 3.
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Reposition the battery compartment sticker: adım 9, 2 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Reposition the battery compartment sticker: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    My sticker began to tear. I decided it may be best to photo the sticker then poke a hole to access the screw.
    Alcove - Yanıt
  10. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unfasten the top housing: adım 10, 2 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unfasten the top housing: adım 10, 2 resimden 2.
    • Use a T8R Torx Security driver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
    I found that for me a T8 H screw (the one with a hole in the middle) works better.
    Violynos - Yanıt
    Hi Violynos, thanks for your comment! The designation Torx T8 security screw is equivalent to Torx T8H.
    Same controller. My screws were T7.
    Alcove - Yanıt
  11. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: adım 11, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: adım 11, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: adım 11, 3 resimden 3.
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: adım 12, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: adım 12, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: adım 12, 3 resimden 3.
    • The USB-C port cover is held in place by two plastic clips.
    • Insert the flat end of a spudger under the right USB-C port cover clip.
    • Pry up with the spudger to release the clip.
    • Repeat the procedure to release the left clip.
  13. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the USB-C port cover: adım 13, 2 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the USB-C port cover: adım 13, 2 resimden 2.
    • Remove the USB-C port cover.
  14. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: adım 14, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: adım 14, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: adım 14, 3 resimden 3.
    • Insert the point of a spudger between the clip on the outer edge of the right bumper and the midframe.
    • Pry out with the spudger to release the right side of the bumper cover.
  15. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: adım 15, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: adım 15, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: adım 15, 3 resimden 3.
    • Insert the point of a spudger between the clip on the outer edge of the left bumper and the midframe.
    • Pry out with the spudger to release the left side of the bumper cover.
  16. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the bumper cover: adım 16, 1 resimden 1.
    • Remove the bumper cover.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Manuel Haeussermann
19.618 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.665 adet Kılavuz yazıldı
4Kılavuz Yorumları
The left bumper button broke for me. The plastic post that presses the button just snapped. This helped me replace the bumper. Good guide.
Jordan Cooper - Yanıt
Removing the handle covers was the hardest part, largely because I was afraid I would break them if I asserted too much pressure. Once I got those off, it was pretty easy. The opening tool and spudger recommended in the tools section were useful--they did their jobs very well--but I suspect this could have been accomplished with any kind of replacement tool(s) you might have on hand; however, since I bought them I'm sure they'll come in handy in future projects. I would argue the TR8 Torx Security Screwdriver is really the only piece of equipment that is specifically required.
Russ Looney - Yanıt
£50 for a new controller, cost but £26 for the tools and spare part, took maybe 10 minutes, and you cannot tell one bit that my controller has been tampered with or fixed
feel truly accomplished, saved money - and now i have the tools for the next challenge, be it my own, or a friends'
Haydn Buchanan - Yanıt
I just broke the bumper cover while following steps 14 and 15 - the guide failed to mention the little plastic posts that actually press the RB/LB buttons are easily snapped while using the spudger to pry the bumper clips. The posts are visible in the picture for step 16 - the long protruding parts nearest the centre of the cover. Maybe consider adding a warning. I'm going to try to glue the posts back on but otherwise will have to just buy a replacement bumper cover part. Excellent guide otherwise.
owwynn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 42
Son 7 gün: 243
Son 30 gün: 1,191
Her zaman: 16,039
