Giriş
Use this guide to replace the accessory antenna board in your Xbox Series X (Digital Edition) gaming console.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your console.
Neye ihtiyacın var
Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.3 mm‑long pancake screw
Two 9 mm‑long screws
Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
Pull the connector straight out of the socket to disconnect it.
Bu adımda kullanılan alet:Dust Blower$18.99
Slide the fan out of its slot to remove it.
Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
Note that the fan can only be installed one way—make sure Master Chief is facing you.
Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
Keep the locking tab held open for the next step.
With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
Remove the base.
Use a spudger to flip open the metal locking tab on the USB port ribbon cable.
Bu adımda kullanılan alet:Tesa 61395 Tape$2.99
Slide an opening pick under the USB port cable to separate the adhesive securing it.
Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
Use a T8 Torx driver to remove the three 7.4 mm‑long green screws securing the center chassis assembly to the shell.
Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
