Ana içeriğe geç
Xbox Series X (Digital Edition) Fan Replacement
Neye ihtiyacın var
  1. Xbox Series X (Digital Edition) Fan Replacement, Uncover the back panel screws: adım 1, 2 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Uncover the back panel screws: adım 1, 2 resimden 2.
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
  2. Xbox Series X (Digital Edition) Fan Replacement: adım 2, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement: adım 2, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement: adım 2, 3 resimden 3.
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  3. Xbox Series X (Digital Edition) Fan Replacement: adım 3, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement: adım 3, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement: adım 3, 3 resimden 3.
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
  4. Xbox Series X (Digital Edition) Fan Replacement: adım 4, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement: adım 4, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement: adım 4, 3 resimden 3.
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  5. Xbox Series X (Digital Edition) Fan Replacement, Remove the back panel screws: adım 5, 2 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Remove the back panel screws: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
  6. Xbox Series X (Digital Edition) Fan Replacement, Unclip the back panel: adım 6, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Unclip the back panel: adım 6, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement, Unclip the back panel: adım 6, 3 resimden 3.
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  7. Xbox Series X (Digital Edition) Fan Replacement: adım 7, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement: adım 7, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement: adım 7, 3 resimden 3.
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  8. Xbox Series X (Digital Edition) Fan Replacement, Remove the back panel: adım 8, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Remove the back panel: adım 8, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement, Remove the back panel: adım 8, 3 resimden 3.
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  9. Xbox Series X (Digital Edition) Fan Replacement: adım 9, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement: adım 9, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement: adım 9, 3 resimden 3.
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  10. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan screws: adım 10, 2 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan screws: adım 10, 2 resimden 2.
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.3 mm‑long pancake screw
    • Two 9 mm‑long screws
  11. Xbox Series X (Digital Edition) Fan Replacement, Disconnect the fan cable: adım 11, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Disconnect the fan cable: adım 11, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement, Disconnect the fan cable: adım 11, 3 resimden 3.
    • Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
    • Grip your tweezers close the connector to get a better grip.
    • Pull the connector straight out of the socket to disconnect it.
    • If you're having trouble, gently rock the connector side to side to loosen it.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  12. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan: adım 12, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan: adım 12, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan: adım 12, 3 resimden 3.
    Dust Blower
    $18.99
    • Slide the fan out of its slot to remove it.
    • During reassembly:
    • Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • Note that the fan can only be installed one way—make sure Master Chief is facing you.
  13. Xbox Series X (Digital Edition) Fan Replacement, De‑route the fan cable: adım 13, 3 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, De‑route the fan cable: adım 13, 3 resimden 2. Xbox Series X (Digital Edition) Fan Replacement, De‑route the fan cable: adım 13, 3 resimden 3.
    • Check if your replacement fan includes a plastic bracket. If it doesn't, follow the next three steps to remove and transfer it.
    • Use your fingers to completely de‑route the fan cable from its grooves on the bracket and pull the connector through its rectangular cutout.
  14. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan bracket screws: adım 14, 2 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan bracket screws: adım 14, 2 resimden 2.
    • Use a T8 Torx driver to remove the four 9 mm‑long screws securing the bracket to the fan.
  15. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan bracket: adım 15, 2 resimden 1. Xbox Series X (Digital Edition) Fan Replacement, Remove the fan bracket: adım 15, 2 resimden 2.
    • Lift the bracket off the fan to remove it.
Sonuç
Spencer Day
153.502 İtibar
1.024 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.738 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 42
Son 30 gün: 104
Her zaman: 1,149
