Ana içeriğe geç
Xbox Series X Wireless Controller Daughterboard Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Xbox Series X Wireless Controller Daughterboard Replacement, Disconnect the antenna cables: adım 1, 3 resimden 1. Xbox Series X Wireless Controller Daughterboard Replacement, Disconnect the antenna cables: adım 1, 3 resimden 2. Xbox Series X Wireless Controller Daughterboard Replacement, Disconnect the antenna cables: adım 1, 3 resimden 3.
    • Slide one arm of a pair of tweezers under the antenna coaxial cable connector, as close to the metal head as possible.
    • Lift the connector straight up to disconnect it.
    • Be sure to lift the coaxial connector straight up off of the socket to avoid bending the connector.
    • Repeat the procedure for the second antenna cable.
    • During reassembly, align the connector over the socket and use your finger to press it into place. A tool like a spudger can slide off and damage the surface-mounted components around the connector.
  2. Xbox Series X Wireless Controller Daughterboard Replacement, Desolder the motor connections: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Silicone Work Mat
    $9.95
    • Use your soldering iron to heat up one of the motor wire solder pads.
    • Once the solder is melted, use tweezers to lift the wire away from the pad.
  3. Xbox Series X Wireless Controller Daughterboard Replacement: adım 4, 2 resimden 1. Xbox Series X Wireless Controller Daughterboard Replacement: adım 4, 2 resimden 2.
    • Desolder the seven remaining wires connecting the four motors to the circuit board.
    • When you resolder these wires during reassembly, make sure to solder the red motor wires to the pads marked SQ3 and SQ7. This ensures that the large rumble motors spin in the correct direction.
  4. Xbox Series X Wireless Controller Daughterboard Replacement, Remove the daughterboard: adım 5, 1 resimden 1.
    • Use a Torx T5 driver to remove the two 7 mm‑long screws securing the daughterboard.
  5. Xbox Series X Wireless Controller Daughterboard Replacement: adım 6, 3 resimden 1. Xbox Series X Wireless Controller Daughterboard Replacement: adım 6, 3 resimden 2. Xbox Series X Wireless Controller Daughterboard Replacement: adım 6, 3 resimden 3.
    • The daughterboard is still connected to the main board by a socket.
    • Insert the flat end of a spudger between the daughterboard and the bottom edge of the frame at the location marked on the image.
    • Twist the spudger to push up the daughterboard and disconnect the socket.
  6. Xbox Series X Wireless Controller Daughterboard Replacement: adım 7, 2 resimden 1. Xbox Series X Wireless Controller Daughterboard Replacement: adım 7, 2 resimden 2.
    • Lift and remove the daughterboard.
  7. Xbox Series X Wireless Controller Daughterboard Replacement, Reassembly tips: adım 8, 3 resimden 1. Xbox Series X Wireless Controller Daughterboard Replacement, Reassembly tips: adım 8, 3 resimden 2. Xbox Series X Wireless Controller Daughterboard Replacement, Reassembly tips: adım 8, 3 resimden 3.
    • During reassembly:
    • Line up the daughterboard socket to the main board socket.
    • Check that the headphone jack isn't out of position.
    • Check that the antenna cables aren't trapped between the two boards.
    • Use your fingers to gently squeeze the boards together to reconnect the socket.
Sonuç
Arthur Shi
283.256 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.625 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 45
