Ana içeriğe geç
Xelio P900A-BK Battery Replacement
Neye ihtiyacın var
  1. Xelio P900A-BK Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
  2. Xelio P900A-BK Battery Replacement: adım 2, 2 resimden 1. Xelio P900A-BK Battery Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
  3. Xelio P900A-BK Battery Replacement: adım 3, 1 resimden 1.
    • Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
  4. Xelio P900A-BK Battery Replacement: adım 4, 3 resimden 1. Xelio P900A-BK Battery Replacement: adım 4, 3 resimden 2. Xelio P900A-BK Battery Replacement: adım 4, 3 resimden 3.
  5. Xelio P900A-BK Battery Replacement: adım 5, 2 resimden 1. Xelio P900A-BK Battery Replacement: adım 5, 2 resimden 2.
    • Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
    • A small amount of heat may be required to safely remove the battery from the adhesive underneath. Use an iOpener or heat gun to soften the adhesive.
    • Do not bend or puncture the battery.
    • Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marcus Nelson
307 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-6, Cichon Spring 2015 UMass Dartmouth, Team 7-6, Cichon Spring 2015 üyesi
UMASSD-CICHON-S15S7G6
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
skatermonkey06 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 357
