Ana içeriğe geç
Xgody D300 Headphone Jack Replacement
Neye ihtiyacın var
  1. Xgody D300 Headphone Jack Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the phone on a flat surface so the back is facing upwards.
  2. Xgody D300 Headphone Jack Replacement: adım 2, 1 resimden 1.
    • Insert the pry tool into the seam and pry the back cover of the case along the seam until the cover is free of the case.
  3. Xgody D300 Headphone Jack Replacement: adım 3, 2 resimden 1. Xgody D300 Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Remove the battery using your hands or the plastic opening tool.
  4. Xgody D300 Headphone Jack Replacement, Headphone Jack: adım 4, 3 resimden 1. Xgody D300 Headphone Jack Replacement, Headphone Jack: adım 4, 3 resimden 2. Xgody D300 Headphone Jack Replacement, Headphone Jack: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the Phillips #00 screwdriver to remove fourteen 3mm screws and one 6mm screw.
    • Use the Phillips #00 screwdriver to loosen three captive screws.
    • Lift the housing along the edges using the opening tool and tweezers. There will be a sticky pad that holds the housing to the smartphone.
  5. Xgody D300 Headphone Jack Replacement: adım 5, 2 resimden 1. Xgody D300 Headphone Jack Replacement: adım 5, 2 resimden 2.
    Desoldering Pump
    $3.99
  6. Xgody D300 Headphone Jack Replacement: adım 6, 1 resimden 1.
    • After the connections have been desoldered, use the tweezers to remove the headphone jack from the motherboard.
    • Place the new headphone jack where the old one was and solder the connections back to together.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 288
