Ana içeriğe geç
Xiaomi Redmi Note Headphone Jack Replacement
Neye ihtiyacın var
  1. Xiaomi Redmi Note Headphone Jack Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
    FixBot'a Sor
    Yorum Ekle
  2. Xiaomi Redmi Note Headphone Jack Replacement: adım 2, 2 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 2, 2 resimden 2.
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    FixBot'a Sor
    Yorum Ekle
  3. Xiaomi Redmi Note Headphone Jack Replacement: adım 3, 2 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Xiaomi Redmi Note Headphone Jack Replacement, Midframe: adım 4, 2 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement, Midframe: adım 4, 2 resimden 2.
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
    FixBot'a Sor
    Yorum Ekle
  5. Xiaomi Redmi Note Headphone Jack Replacement: adım 5, 2 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: adım 6, 3 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: adım 6, 3 resimden 2. Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Xiaomi Redmi Note Headphone Jack Replacement, Rear Camera: adım 7, 2 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement, Rear Camera: adım 7, 2 resimden 2.
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
    FixBot'a Sor
    Yorum Ekle
  8. Xiaomi Redmi Note Headphone Jack Replacement, Motherboard: adım 8, 1 resimden 1.
    • Locate the three ZIF connectors on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Xiaomi Redmi Note Headphone Jack Replacement: adım 9, 3 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 9, 3 resimden 2. Xiaomi Redmi Note Headphone Jack Replacement: adım 9, 3 resimden 3.
    • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
    • Pull the ribbon cable out of the connector by pulling to the left.
    • Repeat these steps for the other two ZIF connectors.
    FixBot'a Sor
    Yorum Ekle
  10. Xiaomi Redmi Note Headphone Jack Replacement: adım 10, 3 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 10, 3 resimden 2. Xiaomi Redmi Note Headphone Jack Replacement: adım 10, 3 resimden 3.
    • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Xiaomi Redmi Note Headphone Jack Replacement: adım 11, 2 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 11, 2 resimden 2.
    • Remove the two 2.9mm Philips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  12. Xiaomi Redmi Note Headphone Jack Replacement: adım 12, 3 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 12, 3 resimden 2. Xiaomi Redmi Note Headphone Jack Replacement: adım 12, 3 resimden 3.
    • Flip over the motherboard to reveal the back.
    • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Xiaomi Redmi Note Headphone Jack Replacement: adım 13, 2 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 13, 2 resimden 2.
    • Lift up the motherboard and turn it over to place it by the side of the phone.
    • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
    FixBot'a Sor
    Yorum Ekle
  14. Xiaomi Redmi Note Headphone Jack Replacement: adım 14, 3 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement: adım 14, 3 resimden 2. Xiaomi Redmi Note Headphone Jack Replacement: adım 14, 3 resimden 3.
    • Use tweezers to peel the vibrating motor off the frame of the phone.
    • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
    FixBot'a Sor
    Yorum Ekle
  15. Xiaomi Redmi Note Headphone Jack Replacement, Headphone Jack: adım 15, 2 resimden 1. Xiaomi Redmi Note Headphone Jack Replacement, Headphone Jack: adım 15, 2 resimden 2.
    • Flip over the motherboard and locate the headphone jack at the top left corner.
    • Desolder the 6 soldered connections on the sides of the headphone jack from the motherboard.
    • Learn how to solder and desolder here.
    FixBot'a Sor
    Yorum Ekle
  16. Xiaomi Redmi Note Headphone Jack Replacement: adım 16, 1 resimden 1.
    • Use tweezers to pull off the headphone jack from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Zongyi Li
1.635 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G4
4 Üyeler
16 adet Kılavuz yazıldı
6Kılavuz Yorumları
You have mentioned it in detailed, but can you mentioned the actual way or sequence of soldering six legs of the jack?
Can you mention the part number of redmi note headphone jack?
link where the jack will be available.
Hemant Kshirsagar - Yanıt Paylaş
I want to buy head phone jack, where the jack will
manu tm manu - Yanıt Paylaş
You can visit iSparehub.com
iSparehub. Com - Yanıt Paylaş
Hey, hast du eine Ahnung, wo man eine Kopfhörerbuchse als Ersatzteil für ein Xiaomi Redmi Note 5 Global herbekommt? Das wäre klasse.
Mathias Bork - Yanıt Paylaş
Redmi note 4 earphone jack replacement Ka price Kya hai
Rinku Poonia - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 79
Her zaman: 41,274
