Ana içeriğe geç
Xtreme Gaming XG-700 Internal Switch Replacement
Neye ihtiyacın var
  1. Xtreme Gaming XG-700 Internal Switch Replacement, Switch: adım 1, 1 resimden 1.
    • Flip the mouse over and peel off the two feet at the bottom of the mouse.
    • Using a Phillips #000 screwdriver, remove the two 5.6 mm screws.
  2. Xtreme Gaming XG-700 Internal Switch Replacement: adım 2, 1 resimden 1.
    • Carefully separate the base of the mouse from the top case as there are ribbon connectors holding the two pieces together.
    • Don't yank or pull the two pieces apart or you will rip the cables.
  3. Xtreme Gaming XG-700 Internal Switch Replacement: adım 3, 3 resimden 1. Xtreme Gaming XG-700 Internal Switch Replacement: adım 3, 3 resimden 2. Xtreme Gaming XG-700 Internal Switch Replacement: adım 3, 3 resimden 3.
    • Carefully remove the two cables from their connection point.
    • The top half of the case can be set aside.
  4. Xtreme Gaming XG-700 Internal Switch Replacement: adım 4, 2 resimden 1. Xtreme Gaming XG-700 Internal Switch Replacement: adım 4, 2 resimden 2.
    • Using a small plastic spudger, release the four clips from each corner of the board.
    • Gently remove the board out of the case.
    • Don't yank or pull the board off the case. There is one cable connecting the board to the case.
  5. Xtreme Gaming XG-700 Internal Switch Replacement: adım 5, 1 resimden 1.
    • Carefully disconnect the ribbon cable from the board.
    • Set aside the case.
  6. Xtreme Gaming XG-700 Internal Switch Replacement: adım 6, 2 resimden 1. Xtreme Gaming XG-700 Internal Switch Replacement: adım 6, 2 resimden 2.
    • Flip the motherboard over, and using a soldering iron, desolder the three switch prongs on each side of the switch.
    • Remove the broken switch.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nam Nguyen
154 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 47
Her zaman: 795
