Ana içeriğe geç
YCCTEAM YCC-SW4001 ABXY Buttons Replacement
Neye ihtiyacın var
  1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Front Case: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
    FixBot'a Sor
    Yorum Ekle
  2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 2, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 2, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 2, 3 resimden 3.
    • Use an opening pick to pry the back cover off of the controller.
    FixBot'a Sor
    Yorum Ekle
  3. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
    FixBot'a Sor
    Yorum Ekle
  4. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Remove two additional screws: adım 4, 1 resimden 1.
    • On some models there are two more Phillips head screws on the sides that need to be removed before the front and back panels can be separated.
    FixBot'a Sor
    Yorum Ekle
  5. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 5, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 5, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 5, 3 resimden 3.
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  6. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 6, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 6, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 6, 3 resimden 3.
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
    FixBot'a Sor
    Yorum Ekle
  7. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 7, 2 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 7, 2 resimden 2.
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  8. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 8, 1 resimden 1.
    • Remove the front case.
    FixBot'a Sor
    Yorum Ekle
  9. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: adım 9, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: adım 9, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: adım 9, 3 resimden 3.
    • Isolate the front cover.
    • Flip over the front cover and remove the four 5.77 mm screws from the back of the front cover using the Phillips #1 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  10. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 10, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 10, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 10, 3 resimden 3.
    • Lift the circuit board from the front cover to expose the back of the buttons.
    FixBot'a Sor
    Yorum Ekle
  11. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 11, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 11, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 11, 3 resimden 3.
    • Remove the rubber caps and the button caps by either dumping them out or taking them out by hand.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Borwick
333 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 494
