Ana içeriğe geç
YCCTEAM YCC-SW4001 ABXY Buttons Replacement
Neye ihtiyacın var
  1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Front Case: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 2, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 2, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 2, 3 resimden 3.
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 4, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 4, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 4, 3 resimden 3.
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 5, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 5, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 5, 3 resimden 3.
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 6, 2 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 6, 2 resimden 2.
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 7, 1 resimden 1.
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: adım 8, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: adım 8, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: adım 8, 3 resimden 3.
    • Isolate the front cover.
    • Flip over the front cover and remove the four 5.77 mm screws from the back of the front cover using the Phillips #1 Screwdriver.
  9. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 9, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 9, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 9, 3 resimden 3.
    • Lift the circuit board from the front cover to expose the back of the buttons.
  10. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 10, 3 resimden 1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 10, 3 resimden 2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: adım 10, 3 resimden 3.
    • Remove the rubber caps and the button caps by either dumping them out or taking them out by hand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Borwick
333 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 317
