Ana içeriğe geç
Yoto Generation 2 Power Adapter Replacement
Neye ihtiyacın var
  1. Yoto Generation 2 Power Adapter Replacement, USB conversion of a Yoto Generation 2 (Big Yoto): adım 1, 1 resimden 1.
  2. Yoto Generation 2 Power Adapter Replacement, Mark your spot to drill: adım 2, 2 resimden 1. Yoto Generation 2 Power Adapter Replacement, Mark your spot to drill: adım 2, 2 resimden 2.
    • Drill a 3/8 inch hole in the back of your Yoto, to the slight left above the battery door. Devices that have dots on the back, the second hole from left makes a perfect pilot hole.
  3. Yoto Generation 2 Power Adapter Replacement, Drill your hole: adım 3, 1 resimden 1.
    • Clean up hole on the back with exacto or file. The hard plastic may need some cleaning depending on your USB size.
  4. Yoto Generation 2 Power Adapter Replacement, insert the USB-C JST 2.0: adım 4, 1 resimden 1.
    • Install USB-C by putting the USB through your hole and tightening the nut. Make sure your USB faces the way you want it to.
    • Begin to reassemble the Yoto, leaving the old circle charger off. Reconnect any items disconnected during SD servicing. Without adding any screws get the battery, speakers (unibody or with additional divider) and the LED back in place. Snake the USB wires and plug into POGO. Do not plug the old power into anything but replace it in the bottom.
    • Screw everything back together! It's done. Enjoy your USB G2
Sonuç
This requires no soldering. You can do it!
Bir başkası bu kılavuzu tamamladı.
RaeL
331 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Love it, but I don’t see a picture of the finished product.
Boo radley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 65
Her zaman: 269
