Ana içeriğe geç
ZTE Quest n817 Power/Volume Button Replacement
Neye ihtiyacın var
  1. ZTE Quest n817 Power/Volume Button Replacement, Battery: adım 1, 3 resimden 1. ZTE Quest n817 Power/Volume Button Replacement, Battery: adım 1, 3 resimden 2. ZTE Quest n817 Power/Volume Button Replacement, Battery: adım 1, 3 resimden 3.
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Power/Volume Button Replacement: adım 2, 2 resimden 1. ZTE Quest n817 Power/Volume Button Replacement: adım 2, 2 resimden 2.
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Power/Volume Button Replacement, Motherboard: adım 3, 1 resimden 1.
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Power/Volume Button Replacement: adım 4, 1 resimden 1.
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Power/Volume Button Replacement: adım 5, 1 resimden 1.
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Power/Volume Button Replacement: adım 6, 1 resimden 1.
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Power/Volume Button Replacement: adım 7, 1 resimden 1.
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Power/Volume Button Replacement: adım 8, 2 resimden 1. ZTE Quest n817 Power/Volume Button Replacement: adım 8, 2 resimden 2.
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
  9. ZTE Quest n817 Power/Volume Button Replacement, Power/Volume Button: adım 9, 1 resimden 1.
    • Each of these buttons can be removed using micro-soldering techniques around either side of the button.
    • Instructions for how to do so can be found at iFixit's How to Solder and Desolder Connections guide.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Loureiro
582 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G6, Peak Fall 2018 UMass Dartmouth, Team S3-G6, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 8
Her zaman: 273
