Ana içeriğe geç
Zebra ZP 450 Power Switch Replacement
Neye ihtiyacın var
  1. Zebra ZP 450 Power Switch Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
  2. Zebra ZP 450 Power Switch Replacement: adım 2, 1 resimden 1.
    • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
  3. Zebra ZP 450 Power Switch Replacement: adım 3, 1 resimden 1.
    • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
  4. Zebra ZP 450 Power Switch Replacement: adım 4, 3 resimden 1. Zebra ZP 450 Power Switch Replacement: adım 4, 3 resimden 2. Zebra ZP 450 Power Switch Replacement: adım 4, 3 resimden 3.
    • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
    • Remove all connections to the motherboard.
  5. Zebra ZP 450 Power Switch Replacement, Power Switch: adım 5, 1 resimden 1.
    • Using the soldering iron, unsolder the joints on the back of the motherboard connecting the power switch to the motherboard.
    • For more information on proper soldering technique, please visit the How to Solder and Desolder Connections guide.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 178
