Ana içeriğe geç
Zeepad 7.0 Screen Replacement
Neye ihtiyacın var
  1. Zeepad 7.0 Screen Replacement, Screen: adım 1, 2 resimden 1. Zeepad 7.0 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Screen Replacement: adım 2, 1 resimden 1.
    • Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
  3. Zeepad 7.0 Screen Replacement: adım 3, 2 resimden 1. Zeepad 7.0 Screen Replacement: adım 3, 2 resimden 2.
    • Disconnect the two ribbon cables between the screen and the motherboard.
    • Be careful not to rip out the ribbon cables or you can harm the ports.
  4. Zeepad 7.0 Screen Replacement: adım 4, 1 resimden 1.
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
  5. Zeepad 7.0 Screen Replacement: adım 5, 2 resimden 1. Zeepad 7.0 Screen Replacement: adım 5, 2 resimden 2.
    • Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
  6. Zeepad 7.0 Screen Replacement: adım 6, 3 resimden 1. Zeepad 7.0 Screen Replacement: adım 6, 3 resimden 2. Zeepad 7.0 Screen Replacement: adım 6, 3 resimden 3.
    • Separate the LCD screen from the metal protecting case with the metal spudger.
  7. Zeepad 7.0 Screen Replacement: adım 7, 3 resimden 1. Zeepad 7.0 Screen Replacement: adım 7, 3 resimden 2. Zeepad 7.0 Screen Replacement: adım 7, 3 resimden 3.
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wires to the new screen wires.
    • How To Solder and Desolder Connections
    • The soldering iron will be extremely hot. Keep out of direct contact to other wires, the motherboard, and especially the battery.
    • Keep out of reach of children.
Sonuç
To reassemble your device, follow these instructions in order.
Bir başkası bu kılavuzu tamamladı.
Harry Winter
157 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G1, Harley Spring 2018 IUPUI, Team S2-G1, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S2G1
3 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
where do you buy the screen?
Zuzzi Z Amend - Yanıt
i need a battery an a screen? is their a place on this page where to get them?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 477
