Ana içeriğe geç
Zeki Droid Tablet Battery Replacement
Neye ihtiyacın var
    1. Zeki Droid Tablet Battery Replacement, Back Casing: adım 1, 1 resimden 1.
      • Remove the back casing by slowly popping each tab out with a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Zeki Droid Tablet Battery Replacement: adım 2, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the tapes one by one from the connecting wires with tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. Zeki Droid Tablet Battery Replacement: adım 3, 1 resimden 1.
      • Remove the black clips from both sides of the casing with a plastic opening tool.
      • The clips should pop off separate from the speakers.
      FixBot'a Sor
      Yorum Ekle
    4. Zeki Droid Tablet Battery Replacement: adım 4, 1 resimden 1.
      • Remove the speakers from the back casing.
      • Do not tug on the speakers because they are connected to fragile wires.
      FixBot'a Sor
      Yorum Ekle
    5. Zeki Droid Tablet Battery Replacement: adım 5, 1 resimden 1.
      • Pull the speakers away from the back casing carefullly.
      FixBot'a Sor
      Yorum Ekle
    1. Zeki Droid Tablet Battery Replacement, Battery: adım 6, 1 resimden 1.
      • To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
      • Do not bend the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Zeki Droid Tablet Battery Replacement: adım 7, 1 resimden 1.
      • To completely disconnect the battery, locate the two metal tabs connected to the small circuit board.
      • Using a soldering tool, you will desolder the tabs from the circuit board.
      • Please refer to the Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır
      • If your replacement battery already has the small circuit board attached, you can desolder the red and black wires connected to the mother board instead of the metal tabs.
      FixBot'a Sor
      Yorum Ekle
    3. Zeki Droid Tablet Battery Replacement: adım 8, 1 resimden 1.
      • To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
      • Please refer to Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır
      • If you have the battery with the circuit board connected, then you can solder the red and black wires back to the mother board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyla
156 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-6, Panko Spring 2015 Colorado Springs, Team 2-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G6
3 Üyeler
20 adet Kılavuz yazıldı
3Kılavuz Yorumları
will this be the same for a tbqc 1065b?
mark campbell - Yanıt Paylaş
how do i replace the screen mine has cracks?
This was my daughter's ...but the yeIIow pack the battery in is BLOWN TIGHT BULGING LIKE A BALLOON. DO I dare try to pry it off...not sure if it will exoIode. Yikes!!! She was murdered so I want to save it
CIaudia Bringe - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 6,070
