Ana içeriğe geç
Zeki TBQG884B Motherboard Replacement
Neye ihtiyacın var
  1. Zeki TBQG884B Motherboard Replacement, Rear Case: adım 1, 2 resimden 1. Zeki TBQG884B Motherboard Replacement, Rear Case: adım 1, 2 resimden 2.
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Motherboard Replacement: adım 2, 1 resimden 1.
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Motherboard Replacement: adım 3, 2 resimden 1. Zeki TBQG884B Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Disconnect the Wi-Fi antenna cable from the motherboard.
  5. Zeki TBQG884B Motherboard Replacement: adım 5, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
  6. Zeki TBQG884B Motherboard Replacement: adım 6, 1 resimden 1.
    • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
  7. Zeki TBQG884B Motherboard Replacement: adım 7, 1 resimden 1.
    • Disconnect the other ZIF connector on the opposite side of the motherboard.
  8. Zeki TBQG884B Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the motherboard and now reinsert all connectors into a new motherboard.
    • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Linlin Cai
317 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S1G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 532
