Ana içeriğe geç
Zenbre SoundBank Z3 Battery Replacement
Neye ihtiyacın var
  1. Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: adım 1, 2 resimden 1. Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Battery Replacement: adım 2, 1 resimden 1.
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Battery Replacement: adım 3, 2 resimden 1. Zenbre SoundBank Z3 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: adım 4, 3 resimden 1. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: adım 4, 3 resimden 2. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: adım 4, 3 resimden 3.
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Battery Replacement, Battery: adım 5, 2 resimden 1. Zenbre SoundBank Z3 Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Zenbre SoundBank Z3 Battery Replacement: adım 6, 2 resimden 1. Zenbre SoundBank Z3 Battery Replacement: adım 6, 2 resimden 2.
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Zenbre SoundBank Z3 Battery Replacement: adım 7, 1 resimden 1.
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Cherian Thomas
334 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G2
5 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Michael Coleman - Yanıt
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
Alier Obed Jaenz Rivas -
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
Alier Obed Jaenz Rivas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 4,573
