Giriş
Are the lights of your Zerodate T26 mouse not functioning when the mouse is on and otherwise working? If so, here’s the guide on replacing your mouse's RGB lights. All you need is a plastic opening tool to gently pry the top, a Phillips #00 screwdriver to open the mouse, and a soldering iron to begin replacing. New LEDs can be purchased online.
Neye ihtiyacın var
Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
