Ana içeriğe geç
Zerodate T26 Scroll Wheel CMOS Sensor Replacement
Neye ihtiyacın var
    1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel: adım 1, 2 resimden 1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel: adım 1, 2 resimden 2.
      • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
      FixBot'a Sor
      Yorum Ekle
    2. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 2, 2 resimden 1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
      • Adhesive pads are located on the bottom of the mouse.
      FixBot'a Sor
      Yorum Ekle
    3. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 3, 2 resimden 1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 3, 2 resimden 2.
      • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 4, 2 resimden 1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 4, 2 resimden 2.
      • Carefully pull the middle shell apart from the bottom plate.
      • The circuit board should then be visible and attached to the bottom plate.
      FixBot'a Sor
      Yorum Ekle
    5. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 5, 2 resimden 1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 5, 2 resimden 2.
      • Remove the scroll wheel by pushing it to the right and pulling up.
      FixBot'a Sor
      Yorum Ekle
    1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel CMOS Sensor: adım 6, 3 resimden 1. Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel CMOS Sensor: adım 6, 3 resimden 2. Zerodate T26 Scroll Wheel CMOS Sensor Replacement, Scroll Wheel CMOS Sensor: adım 6, 3 resimden 3.
      • Remove the battery from the mouse as shown, and set it to the side for later.
      • This should now allow you to gently pull the circuit board up from the bottom of the mouse.
      • Please be very careful when pulling up the circuit board. Yanking it out could result in further damage to the mouse. Make sure you go slow and steady.
      FixBot'a Sor
      Yorum Ekle
    2. Zerodate T26 Scroll Wheel CMOS Sensor Replacement: adım 7, 1 resimden 1.
      • To replace the CMOS sensor attached to the circuit board, carefully de-solder it from the board, found here.
      • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove any circuitry. In order to keep yourself safe and your mouse undamaged, please follow the guide found here to learn to properly solder.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Janice Rullan
662 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Petersen Spring 2023 UMass Dartmouth, Team 2-3, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S2G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 394
