Ana içeriğe geç
Zerodate T26 Side Button Sensors Replacement
Neye ihtiyacın var
  1. Zerodate T26 Side Button Sensors Replacement, Scroll Wheel: adım 1, 2 resimden 1. Zerodate T26 Side Button Sensors Replacement, Scroll Wheel: adım 1, 2 resimden 2.
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
  2. Zerodate T26 Side Button Sensors Replacement: adım 2, 2 resimden 1. Zerodate T26 Side Button Sensors Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
  3. Zerodate T26 Side Button Sensors Replacement: adım 3, 2 resimden 1. Zerodate T26 Side Button Sensors Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
  4. Zerodate T26 Side Button Sensors Replacement: adım 4, 2 resimden 1. Zerodate T26 Side Button Sensors Replacement: adım 4, 2 resimden 2.
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
  5. Zerodate T26 Side Button Sensors Replacement: adım 5, 2 resimden 1. Zerodate T26 Side Button Sensors Replacement: adım 5, 2 resimden 2.
    • Remove the scroll wheel by pushing it to the right and pulling up.
  6. Zerodate T26 Side Button Sensors Replacement, Side Button Sensors: adım 6, 3 resimden 1. Zerodate T26 Side Button Sensors Replacement, Side Button Sensors: adım 6, 3 resimden 2. Zerodate T26 Side Button Sensors Replacement, Side Button Sensors: adım 6, 3 resimden 3.
    • Take out the battery obstructing movement. This should now allow you to gently pull the circuit board up from the bottom of the mouse.
    • Please be very careful when pulling up the circuit board! Yanking it out could result in further damage to the mouse. Make sure you go slow and steady!
  7. Zerodate T26 Side Button Sensors Replacement: adım 7, 1 resimden 1.
    • Carefully clean out any debris that might be obstructing the side buttons.
    • To replace the switches attached to the circuit board, carefully de-solder the two switches found here.
    • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove any circuitry. In order to keep yourself safe and your mouse undamaged, please follow the guide found here to learn to properly solder.
Sonuç
Janice Rullan
662 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Petersen Spring 2023 UMass Dartmouth, Team 2-3, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S2G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 66
