Giriş
This guide shows how to safely separate the main circuit board from the remainder of Zoomer Dino Boomer so that it can be replaced without damage to the electrical system.
Neye ihtiyacın var
Use tweezers to remove all of the colored wire connectors from their sockets on the circuit board.
Use soldering iron and tweezers to disconnect main circuit board from the black and red wires.
Remove main circuit board from Zoomer Dino Boomer
The problem is buying mainboard, Could you write contact informations of the sellers?
Would like to know what is wrong with the circuit board. Is it a bad capacitor, computer chip or other electronic component? Or is it a cracked circuit board? If it is a cracked circuit board, they can be fixed if you solder a wire across the brake in the printed circuit. I save 1 or 2 bad cables from computer accessories and some USB cables for the small thin wire for some of the small stuff. That repair can be difficult if it is a small packed board. But I've repaired many cracked circuit boards from dropped items by soldering a wire across the brake. If it is a component like a capacitor, they can be de soldered and replaced. I had a capacitor go bad in the ECM of my truck, took 30 minutes to replace it. But it took a whole day to R&R the ECM.
But these are great instructions to repair this toy!
5 farklı kişi bu kılavuzu tamamladı.
3 Yorum
can anyone tell me where to get a replacement motherboard?
Nah cuz my dino doesn't show any life support at all just the controller and Idek what's the issue. If this is the way to solve it be so for real tell me where to get that new circuit.
The batteries location?
