Ana içeriğe geç
Zoomer Dino Boomer Nose Sensor Replacement
Neye ihtiyacın var
  1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: adım 1, 2 resimden 1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: adım 1, 2 resimden 2.
    • Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
    • Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
  2. Zoomer Dino Boomer Nose Sensor Replacement: adım 2, 2 resimden 1. Zoomer Dino Boomer Nose Sensor Replacement: adım 2, 2 resimden 2.
    • Use the spudger to pry Zoomer Dino Boomer's lower jaw from its mouth.
  3. Zoomer Dino Boomer Nose Sensor Replacement: adım 3, 2 resimden 1. Zoomer Dino Boomer Nose Sensor Replacement: adım 3, 2 resimden 2.
    • Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
  4. Zoomer Dino Boomer Nose Sensor Replacement: adım 4, 2 resimden 1. Zoomer Dino Boomer Nose Sensor Replacement: adım 4, 2 resimden 2.
    • Carefully push the sensors out of the nose socket with your fingers.
  5. Zoomer Dino Boomer Nose Sensor Replacement: adım 5, 3 resimden 1. Zoomer Dino Boomer Nose Sensor Replacement: adım 5, 3 resimden 2. Zoomer Dino Boomer Nose Sensor Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
    • Use the tweezers to remove the wires as you are soldering them.
    • Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
    • When reassembling, extra solder may be required to reconnect the wires with the circuit board.
  6. Zoomer Dino Boomer Nose Sensor Replacement: adım 6, 1 resimden 1.
    • Remove and replace the nose sensor.
Sonuç
Lauren Mannix
398 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,370
