Ana içeriğe geç
Zoomer Jurassic World Indominus Rex Eye LED Replacement
Neye ihtiyacın var
  1. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: adım 1, 2 resimden 1. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: adım 1, 2 resimden 2.
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Eye LED Replacement: adım 2, 3 resimden 1. Zoomer Jurassic World Indominus Rex Eye LED Replacement: adım 2, 3 resimden 2. Zoomer Jurassic World Indominus Rex Eye LED Replacement: adım 2, 3 resimden 3.
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: adım 3, 2 resimden 1. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: adım 3, 2 resimden 2.
    • Remove the four (4) 7.5mm Phillips screws from the pieces holding the circuit board for the LEDs in place.
    • Use tweezers to pull the circuit board out of place.
    • Pull directly upward! Be careful not to break the circuit board during removal.
  4. Zoomer Jurassic World Indominus Rex Eye LED Replacement: adım 4, 1 resimden 1.
    • Use a soldering iron to disconnect the four (4) wires from the circuit board.
    • Soldering technique guide from iFixit can be found here.
    • Be careful not to burn yourself or the plastic while soldering!
Sonuç
Luke Selby
624 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 354
