Ana içeriğe geç
Zoomer Jurassic World Indominus Rex Motherboard Replacement
Neye ihtiyacın var
  1. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Motherboard Replacement: adım 2, 2 resimden 1. Zoomer Jurassic World Indominus Rex Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Motherboard Replacement: adım 3, 2 resimden 1. Zoomer Jurassic World Indominus Rex Motherboard Replacement: adım 3, 2 resimden 2.
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
  4. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Let the toy rest firmly on a flat surface before processing to the next step.
    • Gently pull each wire out of the connector on the motherboard. Use a set of tweezers, if necessary.
  5. Zoomer Jurassic World Indominus Rex Motherboard Replacement: adım 5, 2 resimden 1. Zoomer Jurassic World Indominus Rex Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the two (2) #0 7.5mm phillips screws from the left side of the motherboard.
    • Remove the one (1) 7.5mm #0 phillips screw from the right side of the motherboard.
  6. Zoomer Jurassic World Indominus Rex Motherboard Replacement: adım 6, 1 resimden 1.
    • Use a soldering iron to remove the red and black wires from the motherboard .
    • Soldering technique guide from iFixit can be found here.
    • Use caution while soldering to avoid being burned.
Sonuç
Anh Le
504 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 809
