Ana içeriğe geç
dreamGEAR Quad Dock Pro LEDs Replacement
Neye ihtiyacın var
    1. dreamGEAR Quad Dock Pro LEDs Replacement, Prerequisite Guide to Accessing Interior: adım 1, 2 resimden 1. dreamGEAR Quad Dock Pro LEDs Replacement, Prerequisite Guide to Accessing Interior: adım 1, 2 resimden 2.
      • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. dreamGEAR Quad Dock Pro LEDs Replacement: adım 2, 2 resimden 1. dreamGEAR Quad Dock Pro LEDs Replacement: adım 2, 2 resimden 2.
      • Remove the six 2 mm PH0 screws on the bottom of the device.
      • Four of those screws are located under the foot pads.
      FixBot'a Sor
      Yorum Ekle
    3. dreamGEAR Quad Dock Pro LEDs Replacement: adım 3, 1 resimden 1.
      • Gently remove the bottom of the device.
      FixBot'a Sor
      Yorum Ekle
    1. dreamGEAR Quad Dock Pro LEDs Replacement, Mother Board: adım 4, 2 resimden 1. dreamGEAR Quad Dock Pro LEDs Replacement, Mother Board: adım 4, 2 resimden 2.
      • Remove the four 1.8 mm J1 screws.
      • Remove the two 2mm PH0 screws.
      FixBot'a Sor
      Yorum Ekle
    2. dreamGEAR Quad Dock Pro LEDs Replacement: adım 5, 1 resimden 1.
      • Gently pick up the mother board
      • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
      FixBot'a Sor
      Yorum Ekle
    3. dreamGEAR Quad Dock Pro LEDs Replacement: adım 6, 2 resimden 1. dreamGEAR Quad Dock Pro LEDs Replacement: adım 6, 2 resimden 2.
      • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
      FixBot'a Sor
      Yorum Ekle
    1. dreamGEAR Quad Dock Pro LEDs Replacement, LEDs: adım 7, 2 resimden 1. dreamGEAR Quad Dock Pro LEDs Replacement, LEDs: adım 7, 2 resimden 2.
      • Desolder the two points following the instructions included in your soldering kit as you remove the light.
      • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
      • You can follow iFixit's guide to soldering here.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob
757 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G4
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 485
