Giriş
This motherboard includes all ports except the DC-In board.
Aletler
Parçalar
- iBook G3 12" 500 MHz Logic Board (128 RAM)
- iBook G3 12" 800 MHz Logic Board
- iBook G3 12" 700 MHz Logic Board
- iBook G3 12" 500 MHz Logic Board (64 RAM)
- iBook G3 12" 600 MHz Logic Board (16 VRAM)
- iBook G3 12" 900 MHz Logic Board
- iBook G3 12" Heat Sink (500 600)
- iBook G3 12" Heat Sink (600 )
- iBook G3 12" Reset Button
- iBook G3 12" Sleep Light
- iBook G3 or G4 Battery Springs
- iBook G3 12" Hinge Grill
- iBook G3 12" 700 (Opaque) 800 900 MHz Metal Framework
- iBook G3 12" 600 (16 VRAM) 700 (Transparent) Metal Framework
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Remove the following 4 screws on the bottom of the computer:
Two 3 mm Phillips from the left side of the computer.
One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
One 14.2 mm Phillips near the front, right corner.
Remove the following 14 screws (some models may be missing a couple of screws):
One 2.5 mm Phillips.
Six 3.5 mm Phillips.
One 4.5 mm Phillips near the sleep light with a small shaft.
Two 4.5 mm Phillips with larger shafts.
Four 5 mm Phillips
If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
Lift the modem from the logic board on the right side, being careful not to strain the display data cable.
Disconnect the modem cable from the left side of the modem.
Slide the modem out of the computer, being careful to avoid catching the black plastic shielding on the surrounding cables.
Your laptop should look approximately like this.
On the bottom of the computer, disconnect the DC-In cable from the logic board.
Turn the remains of the computer over.
Remove the following 6 screws:
One 4 mm Phillips at the upper right corner of the logic board.
One 6 mm Phillips at the front of the computer, near the sleep light.
Two 6 mm small-head Philips from the middle of the logic board
Two 7.5 mm small-head Phillips, one on either side of the battery contacts.
27 farklı kişi bu kılavuzu tamamladı.
