Ana içeriğe geç
iHome iBT16 Motherboard Replacement
Neye ihtiyacın var
  1. iHome iBT16 Motherboard Replacement, Base Plate: adım 1, 2 resimden 1. iHome iBT16 Motherboard Replacement, Base Plate: adım 1, 2 resimden 2.
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: adım 2, 2 resimden 1. iHome iBT16 Motherboard Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. iHome iBT16 Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. iHome iBT16 Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: adım 4, 2 resimden 1. iHome iBT16 Motherboard Replacement: adım 4, 2 resimden 2.
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the plastic cover from the power switch actuator on the motherboard.
Sonuç
Joseph Hazel
329 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,131
