Ana içeriğe geç
iHome iM71SC Base LED Replacement
Neye ihtiyacın var
  1. iHome iM71SC Base LED Replacement, iHome iM71SC Disassembly: adım 1, 1 resimden 1.
    • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
  2. iHome iM71SC Base LED Replacement: adım 2, 1 resimden 1.
    • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
  3. iHome iM71SC Base LED Replacement: adım 3, 1 resimden 1.
    • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
  4. iHome iM71SC Base LED Replacement: adım 4, 1 resimden 1.
    • Remove the now unfastened coverings to expose the internals of the speaker.
  5. iHome iM71SC Base LED Replacement, Base LED: adım 5, 1 resimden 1.
    • Locate the LED on the circuit board.
  6. iHome iM71SC Base LED Replacement: adım 6, 2 resimden 1. iHome iM71SC Base LED Replacement: adım 6, 2 resimden 2.
    • Desolder the three connections to the old LED to remove it from the board.
    • Check out this awesome guide for soldering & desoldering instructions.
Sonuç
To reassemble your device, follow Steps 1-4 in reverse order.
Sarah Brown
301 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G5, Julie Spring 2017 UMass Dartmouth, Team S7-G5, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G5
5 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 221
