Ana içeriğe geç
iHome iPL8 Lightning Connector Replacement
Chen Zhong
Chen Zhong ve başka bir katkıda bulunan
En son June 6, 2019 tarihinde güncellendi
20 dakika
Orta
This guide instructs you to replace the lightning connector in an iHome iPL8. The process includes using two sizes of screwdrivers.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. iHome iPL8 Lightning Connector Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over to access the bottom panel.
    • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
  2. iHome iPL8 Lightning Connector Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Keep turning until the screw and the door are loose.
  3. iHome iPL8 Lightning Connector Replacement: adım 3, 1 resimden 1.
    • Lift and remove the battery access panel.
    • The captive screw will remain attached to the panel.
  4. iHome iPL8 Lightning Connector Replacement: adım 4, 2 resimden 1. iHome iPL8 Lightning Connector Replacement: adım 4, 2 resimden 2.
    • Gently press on the rim of the 3V battery.
    • Remove the 3V battery.
  5. iHome iPL8 Lightning Connector Replacement, Lightning Connector: adım 5, 1 resimden 1.
    • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Remove the four 6mm Phillips #2 screws.
  6. iHome iPL8 Lightning Connector Replacement: adım 6, 1 resimden 1.
    • Remove the four round pads from the bottom of the device.
    • There are two additional 6mm Phillips #2 screws under the pads.
    • Using a Phillips #2 screwdriver, remove the two remaining screws.
    • Put your hand on the silver bottom case and gently pull it outward.
  7. iHome iPL8 Lightning Connector Replacement: adım 7, 2 resimden 1. iHome iPL8 Lightning Connector Replacement: adım 7, 2 resimden 2.
    • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
    • Pull out the green circuit board on the two corners.
    • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
  8. iHome iPL8 Lightning Connector Replacement: adım 8, 2 resimden 1. iHome iPL8 Lightning Connector Replacement: adım 8, 2 resimden 2.
    • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
    • Remove the two screws and the black cover.
    • Gently remove the lightning dock assembly.
    • The lightning dock assembly is connected to wires.
  9. iHome iPL8 Lightning Connector Replacement: adım 9, 3 resimden 1. iHome iPL8 Lightning Connector Replacement: adım 9, 3 resimden 2. iHome iPL8 Lightning Connector Replacement: adım 9, 3 resimden 3.
    • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the back cover.
    • Use your fingers to reposition the lightning connector.
    • Make sure ALL of the lightning connector is exposed.
Sonuç
Chen Zhong
569 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S18-G5, Lore Winter 2019 UC Davis, Team S18-G5, Lore Winter 2019 üyesi
UCD-LORE-W19S18G5
3 Üyeler
3Kılavuz Yorumları
where can I find the replacement lightning connector?
Bond 007 and a Half - Yanıt
Greetings, did you ever find the connector replacement? I am asking so that I can purchase. Thank you in advance for your reply.
Shawn Simmons -
I’m trying to find the replacement part to buy too.
Wendy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 742
